Passat 3C: Speedometer Types and Options
Post14-11-2006, 12:51    Subject: Passat 3C: Speedometer Types and Options Quote
Yes, I know icon_smile.gif.
Can someone tell me the criteria used to determine which speedometers are installed in Passat vehicles?
There are three versions: Lo-Line, Mid-Line, and Hi-Line.
Which model uses the "MFA plus" component?
"Thank you."
Translated on 31-08-2026, 20:17.
Post28-11-2006, 15:12    Subject: Passat 3C: Speedometer Types and Options Quote
Okay, so...
Having now been to the Autostadt and "examined" many Passats, I would statistically say that the "MFA plus" always comes with the Hi-Line dashboard featuring the large central display.
Translated on 31-08-2026, 20:18.
Ross-Tech-Support
Post04-12-2006, 11:25    Subject: Passat 3C: Speedometer Types and Options Quote
The distinction actually applies to all VAG models; sometimes the "Lowline" series might be excluded, but generally, the "Lowline," "Midline," and "Highline" distinctions still apply.
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post04-12-2006, 19:14    Subject: Passat 3C: Speedometer Types and Options Quote
"With the navigation system, the large display is available in all variations. I believe the large display is always included with the Highline model."
"MFG" is an abbreviation for "Mit freundlichen Grüßen," which means "Sincerely" or "Best regards" in English.
Audi SQ5 8R Cvub
Translated on 31-08-2026, 20:19.
Back to top Profile PM Email
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf 4: Replace Analog Speedometer with FIS Display Transmission, Chassis, Body & Interior
No new posts Which Engine? Find the Best Engine Diesel Engine Technology
No new posts VAG-COM Diagnostic Kit for AEL/AAT Engines On-Board Diagnostics (OBD)
No new posts VAG-COM PC: Which Computer to Use? Diesel Engine Technology
