therde
Joined: 09/07/2007 Posts: 26 Karma: +1 / -0 Location: Hannover
24-09-2007, 22:38 Subject: Engine Control Unit Tuning Problems |
Hello NG,
I'm having a problem adjusting my MSG.
Requirements: VAG-COM 704.1, HEX-COM-CAN interface, 400MHz PC running Windows 98.
Skoda, year of manufacture 2006, engine code BSS, 2.0 TDI, series 140 hp, with *** chip tuning.
Ich wollte eigentlich die AGR-Rate verringern bzw. die Soll-Luftmasse? anpassen. Okay.
I logged in using the access code. The control unit also accepted it without any problems.
Okay. If I now want to access a channel within the "Adjustment" function, I get...
"Error cannot be read in the VAG-COM menu." "I've already checked this."
Tried various channels.
The same thing didn't work on a Passat from the year 1998 with engine code AHH.
Does anyone have any ideas?
Thank you, Timo.
Translated on 28-07-2026, 9:40.
Profile PM Email |
vagtuning Guest
24-09-2007, 23:02 Subject: Engine Control Unit Tuning Problems |
So, is it likely that a 03G 906 016 engine control unit (ECU) was installed?
And what do the asterisks mean? Does it have something to do with 'eb*y-chip'?
Translated on 28-07-2026, 9:41.
therde
24-09-2007, 23:06 Subject: Engine Control Unit Tuning Problems |
I need to read out the STG number sometime.
Das ist ein "premium" VW/Audi Tuner mit drei Buchstaben. Somehow, it...
The forum removed "Sternchen" from the name.  .
vagtuning wrote: | So, probably a 03G 906 016 engine control unit is installed?
And what do the asterisks mean? Does it have to do with "eb*y-chip"? |
Translated on 28-07-2026, 9:42.
Profile PM Email |
vagtuning Guest
24-09-2007, 23:21 Subject: Engine Control Unit Tuning Problems |
Could you please provide the complete vehicle history report? Thank you!
It might simply be because it's not working, or more likely, because of the function itself.
simply not desired in the engine electronics and there is no access for customization.
Are there any options for the elderly?
Translated on 28-07-2026, 9:43.
therde
25-09-2007, 12:09 Subject: Engine Control Unit Tuning Problems |
Address 01: Engine; Label file: None.
Part number SW: 03G *** 016 GT, HW: 028 101 269 8.
Component: R4 2.0L EDC G000SG A203.
Encoding: 0000072
Workshop #: WSC 00028
No errors found.
Readiness: 0 0 0 0 0
I spoke with ***. At least from the tuner's perspective, nothing is blocked.
P.S. By any chance, does anyone have a suitable label file?
Timo.
Translated on 28-07-2026, 9:45.
Profile PM Email |
Rudi Guest
25-09-2007, 13:01 Subject: Engine Control Unit Tuning Problems |
Timo
Please check your label files for '03G-906-016-BKD.lbl' and make the necessary edits.
possibly adjust accordingly (or give the Allgäu craft association a good kick in the pants so they don't...).
include their company identifier in the ID string, especially since they also include the version number.
to deface  ).
Actually, your MSTG should respond like this:
Part number SW: 03G 906 016 GT, hardware number: 028 101 269 8.
Component: R4 2.0L EDC G000SG 8203
Encoding: 0000072
Rudi
Translated on 28-07-2026, 9:48.
therde
25-09-2007, 14:09 Subject: Engine Control Unit Tuning Problems |
Is it just a matter of renaming the label file?
Is BKD a different engine code? It should fit, though, right?
I will test it shortly.
-> Result. It seems to be working so far. The information regarding the material safety data sheets appears to be...
Plausible.
Wenn ich mich eingeloggt habe und einen Kanal aufrufen wollte. Appears under.
Adaptation - "Error: Channel xx not available"?
Rudi wrote: | therde wrote: | P.S. By any chance, does anyone have a suitable label file?
Timo |
Please check your label files for "03G-906-016-BKD.lbl" and make the necessary edits.
possibly adjust accordingly (or give the Allgäu craft association a good kick in the pants so they don't).
to deface ).
Part number SW: 03G 906 016 GT HW: 028 101 269 8.
Encoding: 0000072
Best regards, Rudi | .
Translated on 28-07-2026, 9:51.
Profile PM Email |
25-09-2007, 15:59 Subject: Engine Control Unit Tuning Problems |
therde wrote: | | So, just rename the label file? |
While there is currently a label file for the BGW, it has not yet been officially released for use with the BSS. If you feel like it, you could help us out sometime.
http://wiki.ross-tech.com/index.php/Control_Module_Maps
...and generally, in such cases going forward, please let us know and we will add the specific A-B-T part number (can someone please remove this ridiculous censorship, what kind of kindergarten is this?) to the parts list so that it is also covered.
Translated on 28-07-2026, 9:54.
