slight jolting
Bolzer
Karma: +14 / -0   Thank you, like it!
Post05-12-2006, 21:57    Subject: slight jolting Quote
Hi.
I have a G4 ASV with 190,000 km. Recently, I've been experiencing a slight hesitation when lightly accelerating (almost in idle). It disappears under load, whether it's full throttle or normal load. There's nothing noticeable in idle either. I replaced the check valve on the fuel filter because air was getting into the system. Now I don't see any air anymore. This has slightly improved the hesitation, but not eliminated it. I suspect it might be the injectors. I still hope that it's not the case.
Do you have any other ideas?
Best regards, Bolzer.
Post05-12-2006, 22:16    Subject: slight jolting Quote
UI
You've already made 37 posts, and you've never encountered one with "stuttering" or "lag"?
The forum is full of posts about it! Please use the search function.
The quick answer: Disassemble and clean the turnout. In extremely, extremely, extremely bad cases, the only solution is a new ESP.
Instructions for cleaning can be found in the technical articles.
Bolzer
Post05-12-2006, 23:10    Subject: slight jolting Quote
Hi.
Sorry, I've tried searching in various ways, but I haven't found a satisfactory result because the described cases either occurred under load or have different effects. I'll still try cleaning the fuel distributor. For me, it feels like I'm experiencing irregular misfires (misfires only as a description). But this only happens when I'm giving it just enough gas that the engine transitions out of the powerband and runs without load. As soon as the download is complete, the stuttering/lagging disappears.
Post05-12-2006, 23:18    Subject: slight jolting Quote
Yes, exactly this kind of jerky behavior under partial load is something that almost all older VP TDI engines eventually experience, and this specific issue has been described before.
Mostly in the higher gears (4th and 5th) and at lower RPMs, e.g., 1200-1400.
cksIT
Post06-12-2006, 8:09    Subject: slight jolting Quote
@dieselmartinViewing profile: dieselmartin
That was mainly the case with the 1Z engines, right?
Before considering ASV, I would explore other options first.
Post06-12-2006, 10:20    Subject: slight jolting Quote
Yes, it mainly affected the 1Z line.
However, there is no evidence to suggest that it is caused by the MSA12 (which is still an 8-bit system) or by any other unique characteristics of the 1Z.
I think it's more likely that it's simply the statistical age of the 1Zs, which are now massively reaching the 200,000 and 300,000 km mileage marks, and therefore have wear and tear in the MSW (multi-link rear suspension).
His ASV (All-Terrain Vehicle) isn't exactly a brand new vehicle in terms of mileage.
clm24
Post06-12-2006, 11:20    Subject: slight jolting Quote
Hi!
I also experienced a slight jerking (more like a bouncing) between idle and a very small amount of throttle. This was particularly noticeable when driving slowly in first or second gear. Sometimes, there was also a slight jerk when engaging the clutch. I initially thought it was related to the clutch. However, when I recently sealed the valve cover and cleaned the throttle body at the same time, the problem disappeared. The chips were clearly visible on the magnet.
Just sharing this as a personal experience, and to let you know that it can also affect people with ALE.
Good luck with the cleaning!
Best regards, Clemens.
Golf 3 Variant, '97, ALE, 203.000 km
Wenn er nicht so rosten würde...
Post06-12-2006, 11:57    Subject: slight jolting Quote
The ALE is actually also a 1Z icon_wink.gif.
cksIT
Post06-12-2006, 12:27    Subject: slight jolting Quote
That's right, and the ASV is actually a completely different project.
Regarding mileage, the 1Z engine was significantly more prone to issues. In many cases, I've seen cars with mileage below 150,000 km where the bearing material was already starting to degrade.
It has become a problem...
Don't get me wrong, I'm not saying it's impossible, but one should first consider the much more cost-effective alternative solutions. The MSW isn't exactly cheap, especially if you can't clean it yourself.
Post06-12-2006, 15:07    Subject: slight jolting Quote
You can't buy it anyway!
So, either clean the MSW (motor sediment water) filter yourself or replace the pump. I didn't say for sure that it's definitely that. You can only really say that when you're there.
cksIT
Post06-12-2006, 16:35    Subject: slight jolting Quote
dieselmartin wrote:
UI
I just want to prevent him from immediately going for the expensive option...
At Bosch, I was told that there is an MSW (Multi System Workshop) available, but it costs 500€ or more.
No new posts Document, 2.5 l, 6-cylinder / Jerking/Hesitation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BPW Shaking on Audi A4 TDI: Causes & Fixes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku V6 TDI AKE/AYM - Jerking and Lack of Power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AU-AKN Lag: Troubleshooting & Solutions Diesel Engine Technology
No new posts Jerky A6 2.0 TDI PD Diesel Engine Technology
No new posts 1.9 TDI ASZ Misfire: Causes & Fixes Diesel Engine Technology
No new posts TDI Jerking on Audi A6 C4 1.9 TDI Diesel Engine Technology
