Passat 3C: Front Blinkers / Turn Signal Lights
Post12-12-2006, 22:19    Subject: Passat 3C: Front Blinkers / Turn Signal Lights Quote
Hi.
Does the Passat use standard PY21W bulbs in the front headlights, or something else?
Translated on 23-08-2026, 21:08.
Maxx1278
Avatar-Maxx1278
Post13-12-2006, 8:11    Subject: Passat 3C: Front Blinkers / Turn Signal Lights Quote
Hi!
According to the AKTE documentation, it contains an H12V/21W or H12V/21W-LL (long life) bulb.
Best regards.
Maxx.
Translated on 23-08-2026, 21:09.
Post13-12-2006, 8:30    Subject: Passat 3C: Front Blinkers / Turn Signal Lights Quote
Okay.
So, do the "white" turn signals still have an orange diffusing disc inside, like they used to?
Translated on 23-08-2026, 21:10.
Maxx1278
Avatar-Maxx1278
Post13-12-2006, 8:53    Subject: Passat 3C: Front Blinkers / Turn Signal Lights Quote
Looking at the white flashing lights, you can see an orange diffuser.
Therefore, standard white lamps should be installed.
Best regards.
Maxx.
No new posts Avoid squeaking windshield wipers at the front General Tips
No new posts Octavia I 1999 - Front wipers only work when it's dry General Tips
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3c, front fog light, left, long-range light Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat 3bg 1.9 TDI PD / Brake, front left, under pressure Transmission, Chassis, Body & Interior
No new posts Tire Swap: Front to Rear - How To Transmission, Chassis, Body & Interior
No new posts Wheel Bearing A6 (1995) Front Transmission, Chassis, Body & Interior
