from the section "in the digital world, anything is possible, even a little bit of death":
On my laptop, I have installed, among other things, versions 607.2 and 607.3.
Yesterday, while working on the airbag control unit, I noticed that my German .lbl file was not yet in the label folder for version 607.3. So, I got everything back up to date (I gathered all the labels that had been modified most recently for all the Polo ECUs and copied them into the 6.07.3 folder).
Today, I drove again with the MWB 11 and 39 (self-made MWB) and then I was surprised to find that the data in my label file for the MWB 39 were being ignored
Instead, only the "nominal values" from VAGCOM were displayed there: temperature and 3 values representing quantity (instead of LLT, engine speed, opacity, and injection quantity).
The 607.3 is now completely ignoring the label data for MWB 38 through 40.
It accurately displays all the readings up to 37 and from 125 onwards.
And the best part is:
With the same label file (a copy!), version 607.2 works perfectly, just like version 607.3 did before I organized its label folder.
I don't want to rule out the possibility that an outdated redirection might have also ended up in the 607.3 folder... but could that cause a "selective malfunction" within a label file?
