Sporadic Empty Runs AJM Automatic
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
BM
Avatar-BM
Post31-01-2007, 22:37    Subject: Sporadic Empty Runs AJM Automatic Quote
Passat 3B5, year 2000, AJM, Automatic, 85,000 KM
Error Description:
When the vehicle is stationary and the gear is in "Park" or "Neutral", the idle speed fluctuates sporadically for a very short period (approximately 0.5 seconds) to around 1000-1100 RPM, then returns to the normal range in intervals of approximately 10-20 seconds. Emotionally, I would say that the engine speed, before it increases, actually decreases slightly (barely perceptible), similar to a brief interruption.
All error codes are cleared. I suspect the temperature sensor. Unfortunately, the vehicle was already at 65°C during the diagnosis. The corresponding measurements were plausible. After test drive and reaching normal operating temperature, the error was no longer reproducible.
Does anyone have any ideas?
3B5 AJM
Post31-01-2007, 22:47    Subject: Sporadic Empty Runs AJM Automatic Quote
Mhh, could it be that, especially when the engine speed momentarily drops, something is drawing power, and the higher load on the alternator then causes the idle speed to increase?
BM
Avatar-BM
Post01-02-2007, 0:00    Subject: Sporadic Empty Runs AJM Automatic Quote
Hmm, is it possible that, especially when the engine speed briefly drops, something is drawing power, and the increased load on the alternator then causes the idle speed to increase??
Possible, but what? I've turned off everything that I could. Voltage is constant at 14V. I will check it again.
3B5 AJM
BM
Avatar-BM
Post12-02-2007, 19:12    Subject: Sporadic Empty Runs AJM Automatic Translating...
[Translating...]
Denkbar, aber was?
icon_biggrin.gif Lösung : LMM von Herzog icon_exclaim.gif Unglaublich, welche Fehler diese Dinger doch produzieren können.
Wieso ich das hier: https://community.dieselschrauber.org/en/viewtopic.php?t=12257&start=0&postdays=0&postorder=asc&highlight=herzog übersehen habe, entzieht sich meiner Kenntnis icon_eek.gif
Ergo - wo nix vernünftiges drauf steht, ist auch nix vernünftiges drin.
Leider konnte ich zu diesem Zeitpunkt (Samstag Mittag) keinen LMM von Bosch bekommen, sonst wäre das wohl nicht passiert.
Also Finger weg von diesem Zeug!
3B5 AJM
No new posts Sporadic PDC issues Electrical Systems, Vehicle Electronics, Multimedia
No new posts Sporadische Drehzahlschwankung 1.9 TDI BLS 77KW Diesel Engine Technology
No new posts Intermittent power loss on Audi 100 TDi (AAT 115 hp) Diesel Engine Technology
No new posts Nochmal: Sporadische Leistungslöcher bei Audi 100 TDI AAT Diesel Engine Technology
