Adjust Coilover Suspension: How-To Guide
MONCHI
Post24-10-2002, 13:36    Subject: Adjust Coilover Suspension: How-To Guide Quote
...I probably have to ask a silly question.
I want to adjust the height of my coilover suspension. I'm wondering if I should set the left and right sides to the same height based on the number of turns, or not? Someone told me that I should set the driver's side slightly higher because there's more weight on that side. Is that true, or should I set the left side to the exact same number of turns as the right side?
Sure, I'll translate the text for you. Please provide the text you would like me to translate.
GREETINGS
Monchi.
Translated on 02-10-2026, 2:49.
Karma: +807 / -0   Thank you, like it!
Post24-10-2002, 13:56    Subject: Adjust Coilover Suspension: How-To Guide Quote
Hello Monchi,
It depends on how much you weigh and whether you often travel alone.
Some of the older mills I had ridden on were, in fact, slightly lower on the left side.
However, I would still recommend setting the left and right sides to be equal initially. If you find the car is "leaning" after a few years, you can always adjust it slightly or swap the springs between the sides.
Translated on 02-10-2026, 2:51.
Michael748
Post12-11-2002, 14:13    Subject: Adjust Coilover Suspension: How-To Guide Quote
However, in the case of the VW Golf, for example, the engine is mounted slightly to the right of the center. Also, the fuel tank is located more towards the right.
As far as I can tell, the weight distribution between the drivers should be balanced.
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Coilover Suspension Adjustment Guide Transmission, Chassis, Body & Interior
No new posts Do threaded suspension kits require wheel alignment after... Transmission, Chassis, Body & Interior
No new posts Bilstein B16 PSS9 Coilover: Dealers & Sales Transmission, Chassis, Body & Interior
No new posts Threaded suspension Ibiza GT TDI - Problem ?????? Transmission, Chassis, Body & Interior
