Hello everyone,
I have just experienced an issue while having an AGR (Autologous Grafting Reconstruction) procedure, which involves the placement of a metal plate.
During the disassembly of the EGR valve or other actuator, it broke.
When I removed the vacuum hose, I heard a 'pop,' and the nipple...
It broke off and is still stuck in the hose.
Is the actuator available as a separate part, or do you have to replace the entire AGR valve?
buy a new one? It's attached to the EGR housing with 2 TORX screws.
and the 'arm' can be pried out.
Unfortunately, I couldn't find a part number on the item. The part number is...
The complete AGR valve part number is: 038 129 637.
Providing a part number would be helpful; perhaps I can find it here.
Order USA products from your local, patriotic retailer. Unfortunately, nothing works here without them.
Part number...
Here's another picture:
http://www.kuhni.at/Bilder/Ansaugbruecke%20Seite.jpg
Regards...
...Kuhni!
