Adjustable Interior Temp. Setting (22°C) for Auxiliary Heater?
megaonkel
Post29-01-2007, 18:59    Subject: Adjustable Interior Temp. Setting (22°C) for Auxiliary Heater? Quote
What options do I have (using VAG-Com) to change the 22°C interior temperature that is preset by the Climatronic in "Auto" mode, specifically when using the auxiliary heating system?
The fact is that every time the heated seat becomes warm enough and starts preheating the interior, it automatically targets 22°C (regardless of what I had previously set in automatic mode!!). However, the heat required for this interior preheating is diverted from the engine preheating, which is why I've previously been "forced" to run back to the car 5-10 minutes after turning it on to manually adjust the interior temperature to, for example, 16/18°C, in order to achieve a warmer engine.
(This valve 279 (?) is not activated by VW, so the poor engine preheating cannot be due to this.)
Is there no way to change this "mandatory recommendation" regarding the SH (Schlüssel-Halter) operation through VAG (presumably a system or organization)?
(Passat 3C Sedan, 125 kW TDI, Year: 09/2006)
Translated on 09-09-2026, 3:17.
No new posts TDI in limp mode: Troubleshooting guide Diesel Engine Technology
No new posts Climatronic coding not changeable? On-Board Diagnostics (OBD)
No new posts Codierung Tacho Golf4 nicht änderbar! On-Board Diagnostics (OBD)
No new posts Help, I can't get my Maix adapter to work Diesel Engine Technology
