Golf 3 Error Codes: Troubleshooting Guide
ChrisdaKing
Karma: +1 / -3   Thank you, like it!
Post19-01-2007, 16:13    Subject: Golf 3 Error Codes: Troubleshooting Guide Quote
in the fault memory of the following vehicle:
Volkswagen Golf 3, 1.6L engine, AEA code, manufactured in 1995, with 210,000 km mileage, is experiencing the following issue:
00515 Camshaft Position (Hall) Sensor (G40) 03-00-No Signal
The Golf has issues when it's cold (e.g., rough idling) and, in my opinion, has a relatively high fuel consumption (around 10 liters).
What does this error mean? By the way, it reappears after deleting.
Chris.
Translated on 25-09-2026, 1:14.
ChrisdaKing
Post19-01-2007, 16:18    Subject: Golf 3 Error Codes: Troubleshooting Guide Quote
but it seems this has already been clarified.
So, it's probably not a bug, but rather normal behavior?
Chris.
Translated on 25-09-2026, 1:16.
BM
Avatar-BM
Post19-01-2007, 21:22    Subject: Golf 3 Error Codes: Troubleshooting Guide Quote
The Golf has problems when it's cold (e.g., it stutters) and, in my opinion, has a relatively high fuel consumption (~10 liters).
Did you check the plausibility of the engine temperature using VCDS?
Candle holders often cause problems too.
3B5 AJM
Ross-Tech-Support
Post20-01-2007, 21:24    Subject: Golf 3 Error Codes: Troubleshooting Guide Quote
http://wiki.ross-tech.com/index.php/00515
...if in doubt, read the fault codes again with the engine running.
Translated on 25-09-2026, 1:17.
ChrisdaKing
Post20-01-2007, 21:39    Subject: Golf 3 Error Codes: Troubleshooting Guide Quote
ok, thank you icon_smile.gif, I will test it sometime.
No new posts Error code P1351 General Tips
No new posts Error code 01276 - ABS hydraulic pump (V64) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ESP function test, error code 01486 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.5 TDI Error Codes: AAT & More Diesel Engine Technology
No new posts Error code Diesel Engine Technology
No new posts Climatronic Error Codes: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Help with error code On-Board Diagnostics (OBD)
