Bora Tailgate Trim Removal: Guide & Instructions
Jericho
Post24-01-2007, 10:13    Subject: Bora Tailgate Trim Removal: Guide & Instructions Quote
Hello everyone!
'Recently, I've been having a problem with my rear window washer system. It only sprays weakly when I use it, and very little water reaches the window. However, there's water accumulating in the trunk. This is a known issue with VW vehicles. Apparently, the hose that carries the water has come loose somewhere, and some of the water is leaking inside the trim and into the trunk (leaving water stains on the trunk cover). Two weeks ago, I took it to VW. I spent 47 euros, and it lasted about a week. They supposedly installed a clamp. Now, I'm experiencing the problem again.'
My question: How can I remove the rear hatch trim? I've already partially removed it before, but somewhere, which I can't see, it's still attached. Maybe a tip, even with pictures?
Translated on 22-10-2026, 1:24.
No new posts Golf, Bora (from 05.00) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Combination instrument, Golf, Bora, 05.99 to 04.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery drain troubleshooting for Golf IV and Bora Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts How to remove the interior trim panel on the tailgate of ... Transmission, Chassis, Body & Interior
No new posts Airbag Fehler Bora Variant Erfahrungsbericht **Problem:*... On-Board Diagnostics (OBD)
No new posts Remove Mirror Cover: How-to Guide Transmission, Chassis, Body & Interior
No new posts Removing the rocker arm assembly from a 2.0 TDI engine. Diesel Engine Technology
