Gear Ratio & Axle Ratio Audi A3 TDI 81kw
Gasherd
Post10-11-2002, 14:59    Subject: Gear Ratio & Axle Ratio Audi A3 TDI 81kw Quote
Hello everyone,
Does anyone have the gear ratios and axle ratio values for an Audi A3 with 81 kW (AHF engine) and an EBF manual transmission? The car was manufactured in 1998 and is a 1999 model year.
Gas stove.
Translated on 08-09-2026, 7:25.
kenny
Post10-11-2002, 15:25    Subject: Gear Ratio & Axle Ratio Audi A3 TDI 81kw Quote
Okay, I can give you the specifications for the VW Golf IV with the AHF engine and EBF transmission. Since the A3 uses the same platform, I believe the data should be the same. In fact, the specifications are identical for the Seat model that uses the same platform.
Gears (selection from 1-5):
3,778
2,063
1,348
0.967
0.769
I didn't note down the reverse gear ratio, but I think it was something like 3.6...
Axle ratio: 3.389
Translated on 08-09-2026, 7:26.
Post10-11-2002, 18:47    Subject: Forgot Your Tires? Find Tire Shops Near You. Quote
kenny wrote:
So, I can give you the data from a VW Golf IV with an AHF engine and an EBF transmission. Since the A3 has the same platform, I think the data is the same. . .
Hi everyone,
Don't forget the tire size or rolling circumference icon_exclaim.gif in this game.
If they differ significantly (e.g., Golf 3 vs. Golf 4), it is highly likely that the gear ratios of the transmission are also different.
While theoretically a different axle ratio would be sufficient to compensate for the tire size.
Translated on 08-09-2026, 7:28.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Reprogramming Audi A3 81kW AHF / Central Locking System Diesel Engine Technology
No new posts Gear ratio for 1Z and AFN engines Diesel Engine Technology
No new posts Getriebeübersetzung Passat DQS Diesel Engine Technology
No new posts Gear Ratio Calculation CEP Needed Diesel Engine Technology
