Hello Dieselmartin,
First of all, thank you for your detailed explanation.
Subject:
It's impossible to drive the car with the mass airflow sensor plugged in.
But with the diagnostic tool connected, shouldn't the MSG display the replacement value? It's showing zero, and the diagnostic light is on. I can try the diode again, but I've already tried two new mass airflow sensors.
I think the problem might not be with the LMM itself, but perhaps with the cables, as you suggested.
All other values appear to be reasonable.
I will definitely try a cave riding log sometime.
Do you happen to have any additional data regarding the wiring, pinout, or circuit diagram of the mass airflow sensor (MAF) that I could use for troubleshooting?
I have a lot of data here, but unfortunately, I don't have
Thank you very much.
Mati.
