VAG COM 607: Quick Question
acuransx
Karma: +1 / -1   Thank you, like it!
2002 Volkswagen Golf
Post02-02-2007, 14:53    Subject: VAG COM 607: Quick Question Quote
Hello, I think my question is quite simple to answer.
If I have a "Key-Com Interface" (ORIGINAL for 607), can I also use the older VAG versions that are available for free download?
Can I also use the "VAGDASH" program with it?
What if a newer version comes out, like VAG-COM 7...?
Maybe someone can help me... Thank you.
Translated on 30-09-2026, 8:03.
Post02-02-2007, 15:20    Subject: VAG COM 607: Quick Question Quote
acuransx wrote:
Hello, I think my question is easy to answer.
If I had a "Key-Com Interface" (ORIGINAL for 607), could I also use the older VAG versions that can be downloaded for free?
Yes, it should work fine with version 409.1 or later. I've never tried it with older versions.
The activation process depends on the distributor version (it must be the same as the one used with the 607.3 semi-/professional system), and English versions are always activated.
acuransx wrote:
Can I also use the program "VAGDASH" with it?
No, that has nothing to do with it; the program uses its own dongle adapter.
acuransx wrote:
What if a newer version comes out, say VAG COM 7..?
Maybe someone can help me..., Thank you
Keep the newsletter option enabled in the shop, and you'll receive a newsletter. Download and install it from your customer account, and you're ready to go.
Translated on 30-09-2026, 8:05.
acuransx
Post02-02-2007, 15:49    Subject: VAG COM 607: Quick Question Quote
That was fast, thank YOU.
Translated on 30-09-2026, 8:07.
Ross-Tech-Support
Post02-02-2007, 22:36    Subject: VAG COM 607: Quick Question Quote
May I ask the reason?
acuransx wrote:
What if a newer version comes out, say VAG COM 7...?
However, it will still take some time, as the new version will be somewhat more extensive.
No new posts Gear Questions: Small & Simple Answers Transmission, Chassis, Body & Interior
No new posts Small bumps Transmission, Chassis, Body & Interior
No new posts Air Filter Replacement VW Passat 35i TDI 1Z Diesel Engine Technology
No new posts Oil Question: Get Answers Now! Diesel Engine Technology
