Opel Movano EGR Valve: Disable Test (2002)
jörg schmidt
Karma: +21 / -0   Thank you, like it!
Post23-08-2017, 16:59    Subject: Opel Movano EGR Valve: Disable Test (2002) Quote
Hello everyone,
Does anyone know if it's as straightforward as it is with a VAG Euro 3?
I'm having a problem with a stuck (open) EGR valve that has caused my car to be immobilized.
It wouldn't start anymore. The preheating light was constantly on.
Error read: EGR valve open.
Thank you for your tips.
Jörg
Seat Ibiza 6L Sport ASZ EZ Mai 2003
>468000km -schweren Herzens verkauft
Seat Ibiza 6J FR CFHD EZ Mai 2015
>178000km
Fiat Ducato Kasten 2.3 Multijet
EZ 3.2011 >230000km
Translated on 10-08-2026, 5:26.
Karma: +645 / -0   Thank you, like it!
Post24-08-2017, 4:38    Subject: Opel Movano EGR Valve: Disable Test (2002) Quote
Hi Jörg,
Ideally, start by test-fitting a piece of copper sheet or something similar as a sandwich with two gaskets. If the car then runs, install a new EGR valve; otherwise, something else is broken that's causing it not to run.
Best regards, Michi.
Translated on 10-08-2026, 5:28.
jörg schmidt
Post24-08-2017, 17:38    Subject: Opel Movano EGR Valve: Disable Test (2002) Quote
Hi Michi,
Fortunately, it suddenly started working again, and the preheating light remained off.
I would like to understand how the error is generated, specifically how the control unit detects if the EGR valve is constantly open.
I'll see if I can remove the entire EGR system.
Just today, I discovered that we have an ultrasonic cleaning device at the company. I'm going to clean the AGR first. However, I tend to give up immediately when problems arise icon_smile.gif. I really don't feel like tinkering with this thing again.
Jörg
>178000km
EZ 3.2011 >230000km
Translated on 10-08-2026, 5:29.
jörg schmidt
dieselschrauber likes this.
Post24-08-2017, 18:55    Subject: Opel Movano EGR Valve: Disable Test (2002) Quote
The screws that attach the return pipe to the EGR housing were so tight that I was afraid I would break them off.
With the AGR (Abgasrückführung), you can remove a component that is secured with three screws.
I see two screws and I might be able to remove them somehow, but I can't even see the third one.
I've approached the issue with a more optimistic perspective this time, focusing on the simplest and most cost-effective solutions first.
I found a damaged wiring harness. Since the problem first occurred after a drive through heavy rain, I sealed the wiring harness with electrical tape and cable ties.
Maybe I'll get lucky...
Jörg
>178000km
EZ 3.2011 >230000km
Translated on 10-08-2026, 5:31.
No new posts Wind Noise in Audi A2 (8Z0) 2002: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, HVAC failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A2 Noises: 8Z0 MJ 2002 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Opel Movano Water Pump: G9T Engine, 2002 Model Diesel Engine Technology
No new posts Opel Movano: DIY Diagnostic System (G9T, 2002) Diesel Engine Technology
No new posts Opel Movano Fuel System Bleed: G9T Engine (2002) Diesel Engine Technology
No new posts Deactivate fuel injection after oil change Diesel Engine Technology
