19-02-2007, 21:56 Subject: BMR Valve: Function and Purpose Explained |
HI,
another riddle:
What does the green-bordered valve do on the BMR?
The photo was taken standing next to the right fender. The valve's operating rod is connected somewhere near the intake manifold or its vicinity...
| Description: |
| Druckventil am BMR Motor. |
| File size: |
205.79 KB |
| Viewed: |
20156 times |
Translated on 28-07-2026, 15:04.
Profile PM Garage |
Bertil Profi-Schrauber
19-02-2007, 23:32 Subject: BMR Valve: Function and Purpose Explained |
I almost thought that, but for some reason, I was sure he didn't have one.
"Thank you."
Translated on 28-07-2026, 15:05.
Profile PM Garage |
20-02-2007, 16:14 Subject: BMR Valve: Function and Purpose Explained |
dieselmartin wrote: | ... but for some reason, I was sure that he didn't have one.
I wasn't sure either, but the wheels from Tuneline looked so good on your car... I just had to ask about them.
I think it's great that you are engaging with your new [device/system] so intensely. Even if it is not yet necessary...
Translated on 28-07-2026, 15:06.
20-02-2007, 16:21 Subject: BMR Valve: Function and Purpose Explained |
Quote: | | By the way, I think it's great that you're getting so involved with your new one. | Even if it's not strictly necessary yet...
Feel free to reach out to me when you're looking for a new towing vehicle for your campervan, and I can share my experiences then.
The 170 little horses are probably nibbling quite a bit on the trailer }.
Greetings.
Translated on 28-07-2026, 15:07.
Profile PM Garage |
20-02-2007, 16:30 Subject: BMR Valve: Function and Purpose Explained |
Does anyone know when the intake manifold switch activates?
Translated on 28-07-2026, 15:08.
Profile PM Garage |
Malte1408 Schrauber
Joined: 06/23/2005 Posts: 427 Karma: +12 / -0 Location: Hannover
20-02-2007, 17:09 Subject: BMR Valve: Function and Purpose Explained |
Does your BMR actually have an EGR cooler? I once heard that the piezo injectors no longer have an EGR cooler.
20-02-2007, 18:17 Subject: BMR Valve: Function and Purpose Explained |
dieselmartin wrote: | ....
Thank you, but I doubt I'll buy another VW again, and probably not a diesel either... After 23 years of owning VWs (plus the ones still to come with my AXR), I'll probably buy something different (... it's good that I said that before buying my AXR too...  ).
Quote: |
The 170 little horses are probably nibbling quite nicely on the trailer .
Yep, I believe you... But it's still a VW  . And that with an injection system from my employer...
Translated on 28-07-2026, 15:09.
tdi pumpe düse Guest
20-02-2007, 19:33 Subject: BMR Valve: Function and Purpose Explained |
Hello everyone,
BMR engines all have an EGR cooler.
The variable intake manifold is needed in the partial load range to provide better swirl of the incoming air.
The valve is for the bypass air duct.
Regarding the question of why use a plastic suction tube, it's about weight reduction and cost savings...
Martin, why don't you just ask via private message? You know the reason.
Translated on 28-07-2026, 15:11.
mserge Schrauber
Joined: 06/20/2005 Posts: 923 Karma: +6 / -0 Location: Luxemburg
21-02-2007, 10:44 Subject: BMR Valve: Function and Purpose Explained |
dieselmartin wrote: | Quote: |
Greetings.
m; |
"Mmmh, the tire dealers will be happy too when there are 1000 kg hanging off the back and 170 horsepower thoroughbreds pulling at the front axle." |
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 28-07-2026, 15:12.
21-02-2007, 11:35 Subject: BMR Valve: Function and Purpose Explained |
Unfortunately, the four-legged version is only available with 140 horsepower...
Translated on 28-07-2026, 15:13.
Profile PM Garage |
mserge Schrauber
21-02-2007, 11:41 Subject: BMR Valve: Function and Purpose Explained |
dieselmartin wrote: | Unfortunately, the four-legged version is only available with 140 horsepower...
m; |
It seems that this is the intended approach within this company. The Skoda Octavia 4x4 was previously only available with a 100 hp engine, but now that the 170 hp engine is offered, it's also available with a 140 hp option.
polo2f Guest
21-02-2007, 12:29 Subject: BMR Valve: Function and Purpose Explained |
What is the purpose of having all-wheel drive (4x4) in Germany?
Translated on 28-07-2026, 15:14.
mserge Schrauber
21-02-2007, 13:33 Subject: BMR Valve: Function and Purpose Explained |
polo2f wrote: | | Why would someone need a 4x4 vehicle in Germany? |
For example, when you have to drive a somewhat larger trailer or caravan.
Or perhaps something more suitable for mountainous regions where you want to be able to navigate well through the snow.
I didn't want to start a "pros and cons of 4x4" discussion right now.
21-02-2007, 13:36 Subject: BMR Valve: Function and Purpose Explained |
Please don't turn my 16V-TDI thread into a 4motion thread  .
It appears that not all 16V TDIs have a shift lock. The BKD engine, for example, does not have one, as revealed by SSP 316.
Translated on 28-07-2026, 15:15.
Profile PM Garage |
Aron Blaumann
Joined: 10/26/2006 Posts: 440 Karma: +5 / -1 Location: KC
21-02-2007, 17:33 Subject: BMR Valve: Function and Purpose Explained |
m; |
Hi there...
Do the machines perhaps have a different torque characteristic? Or could it also be related to the power output? At 4200 rpm, it only delivers its full potential. For the relatively small valve size, you need aggressive valve timing, and that requires a good Venturi effect at low RPMs. Perhaps this is also related to the emission classification/vehicle weight and similar factors?
Translated on 28-07-2026, 15:17.
