Automatic Transmission Repair: VW Passat 1.9 TDI
Dietmar Stüttger
Post10-11-2002, 22:12    Subject: Automatic Transmission Repair: VW Passat 1.9 TDI Quote
Can anyone help me?
I drive a 1998 Passat TDI (AHU) with a 4-speed automatic transmission.
The vehicle has the following issue:
The transmission shifts very roughly between the 2nd and 3rd gears; specifically, the shift to 3rd gear is jerky when there's no load, but it shifts smoothly under load.
I have already replaced the sliding case, but it didn't improve anything. Volkswagen wanted to install a new transmission, but that was too expensive for me.
The car has approximately 185,000 kilometers on the odometer.
I hope you have some ideas.
Dietmar.
Translated on 31-07-2026, 21:06.
Tobias
Post11-11-2002, 9:24    Subject: Automatic Transmission Repair: VW Passat 1.9 TDI Quote
Hi Dietmar,
'With a 98 [model], shouldn't it already have a 5-speed transmission?'
'Never mind... so, replacing the hydraulic control unit didn't solve the problem?'
Then I'm betting on a broken coil spring.
Greetings from Lake Constance.
Tobias.
Translated on 31-07-2026, 21:08.
Tobias
Post12-11-2002, 10:40    Subject: Automatic Transmission Repair: VW Passat 1.9 TDI Quote
Hello everyone, hello Dietmar.
You asked me what the function of a Belleville washer is in a gearbox.
Since I think this might interest more people, I'm quickly posting it here.
During the rapid filling of the clutch, the clutch piston moves towards the friction disc pack. To ensure that the 'engagement' of the piston with the friction disc pack is smooth (without any noticeable jolts), coil springs are used.
These are hardened steel discs in the shape of a corrugated washer, only much larger.
'Well capacitors are also needed in rolling circuits to prevent switching spikes.'
Tobias.
Translated on 31-07-2026, 21:09.
Dietmar Stüttger
Post12-11-2002, 16:58    Subject: Automatic Transmission Repair: VW Passat 1.9 TDI Quote
Hello Tobias,
Thank you for your reply.
How do you replace the leaf spring?
Could it really be due to that part?
The circuit works with...
It's better (good) in other gears.
Dietmar.
Translated on 31-07-2026, 21:11.
Tobias
Post12-11-2002, 17:02    Subject: Automatic Transmission Repair: VW Passat 1.9 TDI Quote
It's possible that the other circuits are working correctly...in fact, it's quite likely.
Since each clutch or brake in the stepped automatic transmission has its own coil spring.
But:
Such 'remote diagnoses' are always just guesses or based on experience.
I can't tell you how it's changed in your transmission.
But definitely remove the gearbox, disassemble it, inspect it, reassemble it, and install it.
Tobi.
Translated on 31-07-2026, 21:12.
Dietmar Stüttger
Post12-11-2002, 22:47    Subject: Automatic Transmission Repair: VW Passat 1.9 TDI Quote
Hello Tobias,
It sounds like a lot of work (disassembling the transmission, etc.).
I suppose I'll just have to live with the problem. My wife drives the car anyway, so I only have to put up with her complaining about it occasionally. It will pass.
Too bad, I thought more people would respond to my message.
'Nevertheless, thank you very much for your effort.'
Dietmar.
Translated on 31-07-2026, 21:14.
No new posts Doku Passat MJ 2000 Beleuchtung Sonnenblende defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic 01N with AFN Engine - Problem with the Gearbox ... General Tips
No new posts Doku Golf 5, Problems with windshield washer/water system Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission AFN: Gearbox-Axle Assembly Oil Cha... Diesel Engine Technology
No new posts Automatic Transmission Coding: A6 C4 AEL On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Steuergerät AFN Automatik auf Getriebe codieren On-Board Diagnostics (OBD)
No new posts Zeitweise starke Quitschgeräusche beim Automatik Getriebe Diesel Engine Technology
