Hello everyone,
Currently, I'm preoccupied with the following:
Is an air mass of 480 mg/H at idle, without EGR, normal?
(Engine running at operating temperature)
That seems like a lot to me.
The maximum EGR valve setting of 69%, which is controlled by the engine control unit (ECU) during normal operation, is just enough to reach the already highly adapted air mass value of 380 mg/H.
In the default MWB 3 setting, with a control value of 100%, the air mass is 230 mg/H.
Is my mass airflow sensor
reading too high, or is my EGR valve sticking or not opening far enough?
Please, if anyone has an AGR (Exhaust Gas Recirculation) valve or a similar device, could you please post the target/actual values and the air mass values (target value 0 / 100%) at idle, as well as the basic settings for MWB 3?
Thank you very much and best regards.
Malte.
