Brake Light Error: Handbrake Warning Light
Glöckner Guido
Post21-02-2007, 18:59    Subject: Brake Light Error: Handbrake Warning Light Quote
Hello dear colleagues,
I'm having a problem with the handbrake warning light on my Passat TDI 1.9 4Motion.
After driving approximately 30-50 kilometers, the warning light illuminates (indicating the parking brake is engaged).
The handbrake switch and brake fluid reservoir have already been replaced. WHAT ELSE COULD IT BE?? HELP PLEASE.
Translated on 24-09-2026, 15:24.
mserge
Post21-02-2007, 19:01    Subject: Brake Light Error: Handbrake Warning Light Quote
Can I check the error memory at the exact moment the light turns on?
What do the brake pads look like?
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 24-09-2026, 15:25.
Glöckner Guido
Post21-02-2007, 19:04    Subject: Brake Light Error: Handbrake Warning Light Quote
The brakes were completely replaced about 5,000 km ago, and the problem only occurs while driving, not when the car is stationary.
I was thinking about doing a test while driving to see if there might be a problem with one of the ABS sensors. ???
mserge
Post21-02-2007, 19:08    Subject: Parking Brake Warning Light Error: Troubleshooting Quote
Glöckner Guido wrote:
Brake fluid reservoir has already been replaced, PLEASE
Warum wurde der getauscht? Auch der Geber? Ist genug Flüssigkeit drin und bleibt sie auch drin? On Max?
Could something be obstructing the handbrake lever from being fully depressed?
Translated on 24-09-2026, 15:26.
Glöckner Guido
Post21-02-2007, 19:12    Subject: Brake Light Error: Handbrake Warning Light Quote
The container was replaced with caution and under suspicion of a potential issue related to a Volkswagen master technician.
The customer is now with me, and I'm trying to resolve the issue.
"Handbrake helper" is obviously a typo; I've already corrected that small error.
I think it might be related to the ABS/ESP system or a circuit board.
Ihr Partner wenn es um Reifen geht.
www.Gloeckner-Motorsport.de
No new posts Parking Brake Stuck - Audi A2 8Z0 MJ 2002 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Parking brake - All-wheel drive Diesel Engine Technology
No new posts Handbremse Kontrolleuchte On-Board Diagnostics (OBD)
No new posts Rear axle and handbrake for VW Golf IV? Transmission, Chassis, Body & Interior
No new posts Parking brake not releasing!! Transmission, Chassis, Body & Interior
