Doku Sharan 7M8: Reduced Steering Assist (Solution)
Michael II
Post29-01-2003, 11:53    Subject: Doku Sharan 7M8: Reduced Steering Assist Quote
Reduced power steering assist.
Cause.
Water ingress between the longitudinal member on the right side and the soundproofing tray causes the ribbed V-belt for the power steering pump to slip.
Solution:
1. Check the V-belt and replace it if necessary.
(a worn-out V-belt can contribute to slippage).
2. Check if the towing eye cover is installed in the front; if not, install it.
3. Check if the ribbed belt is slipping due to water ingress between the soundproofing pan and the longitudinal member. If this is the case, please replace the soundproofing pan.
Tschüss
Michael II
Translated on 16-10-2026, 1:50.
Ratings - Doku Sharan 7M8: Reduced Steering Assist
No new posts Polo 9N: Power Steering Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2002, No Power Steering Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB ANU Engine Noises: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Seat for VW Sharan 7N Diesel Engine Technology
No new posts STG Cornering Light Sharan 7N Electrical Systems, Vehicle Electronics, Multimedia
No new posts VR6 Misfire: AYL, Sharan - Cylinder 1, 3, 5 On-Board Diagnostics (OBD)
No new posts TDI Pistons for VW Sharan Upload
