AHF Tdi. Does it work with any control unit?
timthaler78
Post16-02-2007, 9:32    Subject: AHF Tdi. Does it work with any control unit? Quote
Good morning.
According to the VW workshop, my engine control unit (ECU) is faulty.
I'm now looking for a used one.
My part number is: 038 906 018 BM.
Now I've seen that there are also part numbers like 038 906 018 AJ, etc. for the AHF engine.
Does it work with that?
Thank you for the responses.
Best regards, Tim.
Rudi
Post16-02-2007, 10:11    Subject: AHF Tdi. Does it work with any control unit? Quote
It might work, but it's not guaranteed! WFS definitely needs to be adjusted.
What leads the workshop to the conclusion that the MSTG is obsolete?
Rudi
timthaler78
Post16-02-2007, 10:24    Subject: AHF Tdi. Does it work with any control unit? Quote
I have no idea.
"Belief" is in the error log.
What are the differences between the control units?
The letters are just called differently.
Rudi
Post16-02-2007, 11:50    Subject: AHF Tdi. Does it work with any control unit? Quote
Belief can help - but not in this case icon_wink.gif.
What does the printout say?
Software is definitely different. Hardware can be different.
Different versions of WFS (Web Feature Service) may be used.
A single letter... 028 906 021AF vs. 028 906 BF... just one letter;
Despite this, they are completely different control units.
Why did you go to VW by car?
timthaler78
Post18-02-2007, 11:28    Subject: AHF Tdi. Does it work with any control unit? Quote
Is there a list that specifies the versions?
Rudi
Post18-02-2007, 16:50    Subject: AHF Tdi. Does it work with any control unit? Quote
If you find one, I'd like a copy.
timthaler78
Post19-02-2007, 19:17    Subject: AHF Tdi. Does it work with any control unit? Quote
I was at VW today. They don't know if the others will fit.
My car is running fine, with an *** control unit. It needs to be removed now, because it's for sale.
I bought this specifically for that purpose. With mine, I always get the same error message. I think the boost pressure regulation isn't working correctly. It does run, though. But how about an SDI?
timthaler78
Post16-03-2007, 21:05    Subject: AHF Tdi. Does it work with any control unit? Quote
I saw that there's also the 038906012L part available for the AHF engine.
Has anyone ever tried something like this before?
Would it work with that? The "012L" designation makes me suspicious.
Or does anyone know what the difference is compared to the previous model, 038906018BM?
Best regards, Tim.
Post17-03-2007, 16:02    Subject: AHF Tdi. Does it work with any control unit? Quote
I found some IHMO 3 018 spark plugs that are compatible with my car.
My test control unit is the 018 AE (90 hp TDI ALH).
Rudi
Post19-03-2007, 7:07    Subject: AHF Tdi. Does it work with any control unit? Quote
I saw that there is also the 038906012L part available for the AHF engine.
Would it work with that? The '012L' designation makes me suspicious.
Greetings, Tim.
The 012xx model has completely different connectors. You would need to replace the wiring harness.
Rudi
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not working properly Diesel Engine Technology
No new posts A4 2.0 TDI Germany: Runs poorly during regeneration + fue... Diesel Engine Technology
No new posts LMM Cable to Ground - Only with ECU Connected On-Board Diagnostics (OBD)
No new posts AC Running with Recirculation Below +2°C? Transmission, Chassis, Body & Interior
