VWGOLFIII Guest
18-11-2002, 10:39 Subject: Lip filler check: Is it safe? |
Hi.
Is it possible to check the glow plugs while they are still installed, for example, using an ohmmeter or something similar? And what should the resistance value be for the glow plugs?
Thank you, and best regards, Mark.
Translated on 18-09-2026, 3:32.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
18-11-2002, 10:57 Subject: Lip filler check: Is it safe? |
Hi, we've already discussed this, so please use the search function – it's your friend.
Profile PM WWW Garage |
VWGOLFIII Guest
18-11-2002, 11:12 Subject: Lip filler check: Is it safe? |
Hi.
Thank you, but I can't find anything using the search option. Do you still have the link? If so, could you please send it to me?
Translated on 18-09-2026, 3:33.
Bertil Profi-Schrauber
18-11-2002, 11:28 Subject: Lip filler check: Is it safe? |
Translating... |
