Lip filler check: Is it safe?
VWGOLFIII
Post18-11-2002, 11:39    Subject: Lip filler check: Is it safe? Quote
Hi.
Is it possible to check the glow plugs while they are still installed, for example, using an ohmmeter? And what should the resistance value be for a good glow plug?
Thank you, and best regards, Mark.
Translated on 24-07-2026, 17:27.
Post18-11-2002, 11:57    Subject: Lip filler check: Is it safe? Quote
Hey, we've already discussed that; the search function is your friend.
Translated on 24-07-2026, 17:28.
VWGOLFIII
Post18-11-2002, 12:12    Subject: Lip filler check: Is it safe? Quote
Hi.
Thank you, but I can't find anything using the search function. Do you still have the link? If so, could you please send it to me?
Post18-11-2002, 12:28    Subject: Lip filler check: Is it safe? Translating...
[Translating...]
/viewtopic.php?t=1477
This topic is locked, you cannot edit or reply. LMM Check: No Diagnostic Tool Needed Diesel Engine Technology
