Why doesn't the vehicle's onboard network recognize my Climatronic?
Post30-03-2007, 12:45    Subject: Why doesn't the vehicle's onboard network recognize my Climatronic? Quote
HI,
In the vehicle's onboard network control unit (ECU), you can mark virtually anything as "installed."
Why isn't it done in a way that reflects reality?
I have a Climatronic system, but that bit is not set.
After installing the ";)footwell lighting}", I also installed it in the MFA Plus... now all that's left to do is install and wire the lamps }.
Translated on 13-07-2026, 22:59.
Ross-Tech-Support
Post30-03-2007, 21:48    Subject: Why doesn't the vehicle's onboard network recognize my Climatronic? Quote
There's no need to worry; the VAG-COM version you're using apparently still contains the "old" data for the onboard computer control unit coding. The specific bit in question only applies to Audi models and should be ignored for Volkswagen models.
Translated on 13-07-2026, 23:00.
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Error code Climatronic 3B, model year 1999, 2000 model Troubleshooting & Guides
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts tdi ruckeln - meiner jetzt auch - vielleicht weiss wer rat Diesel Engine Technology
No new posts SKANDAL_Monteur weiss nicht weiter bei ÖLDRUCKGEBER ! Diesel Engine Technology
No new posts XR Stuttering. I don't know what to do anymore... Diesel Engine Technology
No new posts Why isn't the engine smoking so much? Diesel Engine Technology
