floppine Guest
19-11-2002, 19:22 Subject: Engine Revs High After Warm Start |
I've been experiencing a sporadic problem with my 2000 Passat, which has an AJM engine, specifically when starting it when the engine is warm.
Sometimes, immediately after starting, the engine revs up to approximately 2000 RPM, and the speed fluctuates around that value with a frequency of about 4 Hz.
Approximately +/- 100 RPM (it sounds like a nervous scooter driver). This lasts for about 2 seconds, and then the speed returns to the normal value. This effect occurs more frequently when the outside temperature is above 20 degrees Celsius and when the engine has been idle for 5-10 minutes.
floppine
Translated on 21-09-2026, 1:36.
Markus H. Guest
20-11-2002, 0:57 Subject: Known. I know it. |
I used to experience that occasionally with my Golf 1Z as well.
Also, this typically happens in warm temperatures, and especially after driving for a long time at a fast pace.
I always believed (or still believe) that this is intentionally done by the engine control unit.
Perhaps to clear the engine of any obstructions, or to quickly restore oil pressure.
It sounds like there's a 'ghost foot' effect, where the accelerator is briefly pressed multiple times immediately after starting the engine, right?
I cannot give you a specific answer as to why this issue has only recently started occurring in your car.
Translated on 21-09-2026, 1:37.
20-11-2002, 19:17 Subject: Re: I know. |
Markus H. wrote: |
It sounds like there's a "ghost foot" effect, where the accelerator is briefly pressed multiple times immediately after starting the engine, right?
Hi everyone,
If that were intentional, it would probably happen with every car. But it's not, which suggests there's likely something wrong with your cars.
Maybe you'll find something in the error database.
I vaguely remember having read something similar before, but I no longer have any idea about the cause.
Translated on 21-09-2026, 1:39.
Profile PM Garage |
Markus H. Guest
20-11-2002, 22:11 Subject: Engine Revs High After Warm Start |
My Golf has been doing that occasionally for the last 150,000 kilometers.
If it's lazy, it can't be a drama (at least, not for me).
Of course, I don't know how often this happens to you - and I don't want to downplay it at all!!
Translated on 21-09-2026, 1:40.
floppine Guest
21-11-2002, 9:24 Subject: Engine Revs High After Warm Start |
Hello everyone,
It happens to me about twice a month. I also experienced it the day before yesterday, even with low outside temperatures. Could it possibly be air bubbles in the fuel supply? The PD engine has a complex and therefore potentially problematic fuel cooling system.
floppine
Translated on 21-09-2026, 1:41.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
Profile PM WWW Garage |
23-11-2002, 21:23 Subject: Engine Revs High After Warm Start |
Hello again.
I just found what I vaguely remembered.
/viewtopic.php?t=15
I, of course, don't know if that applies to PDs as well...
Translated on 21-09-2026, 1:43.
Profile PM Garage |
floppine Guest
12-12-2002, 12:32 Subject: Engine Revs High After Warm Start |
I found the problem: the coolant temperature sensor is defective. It wasn't a complete failure, but it only malfunctions at certain temperatures (around 50 degrees Celsius), causing the reading to jump and the engine to register a temperature below zero.
To diagnose the issue, I used the Climatronic function diagnostic tool. Channel 45 displays the coolant temperature, which allowed me to observe the behavior clearly.
floppine
12-12-2002, 17:35 Subject: Error Database: Comprehensive Guide & Solutions |
Hi Rainer,
If there were a category in the error database for "exotic, but I've seen it before," I would move the article there...
What do you think about that?
Translated on 21-09-2026, 1:44.
Profile PM Garage |
12-12-2002, 17:48 Subject: Engine Revs High After Warm Start |
Yes  Thank you very much for the feedback, floppine!
Translated on 21-09-2026, 1:45.
