Golf 3: Pump Düse Conversion Guide
micha tdi
Post14-04-2007, 0:51    Subject: Golf 3: Pump Düse Conversion Guide Quote
hi
I'm currently in the process of converting my Golf 3 to a 1.9L TDI PD engine from a Golf 4, with 100 horsepower.
The engine is already installed!
What about the electrical system? Where can I find a suitable wiring diagram?
What should one consider regarding electrical work?
Do I have everything I need, like the speedometer, etc.?
micha
Translated on 31-10-2026, 3:21.
matt
Post18-04-2007, 14:48    Subject: Golf 3: Pump Düse Conversion Guide Quote
It's obviously great that these questions weren't clarified before the renovation.
Well, you can actually buy the wiring diagrams. The dealership usually has a few file folders for each vehicle with repair guides, etc. A more sophisticated approach would be to use specialized software.
Translated on 31-10-2026, 3:22.
No new posts Replacing injector nozzles in common rail injectors Troubleshooting & Guides
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Timing Chain Wear: Inspection & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Pump Düse conversion in Golf 3 Diesel Engine Technology
No new posts Golf 4 Performance Issues: 110 HP Pump Denoise Diesel Engine Technology
No new posts TDI Golf 4: Convert to Pump Duse System Diesel Engine Technology
No new posts Golf 4 Engine Swap: 110PS to 150PS PD. Diesel Engine Technology
