Pump Connector Part Number: Find Yours Now!
suggermilk
Post26-11-2002, 21:35    Subject: Pump Connector Part Number: Find Yours Now! Quote
I was planning to order the parts for my tuning box today, but the dealer couldn't find the part numbers for the 10-pin connector.
Does anyone know the part numbers, or could someone quickly check theirs? I urgently need them.
'There are no markings on the connectors for me; the previous owner probably messed with something, because all the connectors in my engine compartment are painted dark blue.'
It doesn't really matter, though.
Please help me.
I only need the two numbers for the 10-pin pump connector.
Thank you.
Translated on 27-08-2026, 4:39.
Post27-11-2002, 8:07    Subject: Pump Connector Part Number: Find Yours Now! Quote
actually, you could use the search function icon_smile.gif but I don't want to be that person icon_smile.gif.
Pump connector:
10-pole version.
357 972 741 / 20 pieces of seals.
1J0 973 735 / 1 piece flat connector housing.
1J0 973 835 / 1 piece flat connector housing.
000 979 131 / 5 Sentence Single-line.
(Edited by Dieselmartin on 6.11.04)
NO, the 131s are failing.
You need five times.
000 979 133
see here: https://community.dieselschrauber.org/en/viewtopic.php?p=50191
Please provide the text you would like me to translate from German to English.
000 979 134 / 5 Sentence Single-line.
8-pole version.
357 972 741 / 16 pieces of seals.
3A0 973 834 / 1 piece housing.
3A0 973 734 / 1 piece housing.
000 979 129 / Set of 4 cables.
000 979 133 / Set of 4 pieces.
Translated on 27-08-2026, 4:42.
Maik
Post28-11-2002, 10:33    Subject: Pump Connector Part Number: Find Yours Now! Quote
I have a question about the numbering.
What are lead sentences used for?
Actually, I need the contacts for crimping, or are the contacts already crimped onto the wires?
Maik.
Translated on 27-08-2026, 4:44.
Andy
Post28-11-2002, 10:44    Subject: Pump Connector Part Number: Find Yours Now! Quote
Sure.
On each cable, two connectors are pre-crimped.
Translated on 27-08-2026, 4:45.
Rudi
Post28-11-2002, 10:52    Subject: Pump Connector Part Number: Find Yours Now! Quote
At 'Freundlichen,' they no longer offer loose crimp connectors (supposedly for reasons of manufacturing safety), which, considering the delicate pliers/inserts and their prices, is somewhat understandable.
Instead, there are pre-made cables of approximately 50cm in length with a contact at each end (for about 1 EURO per piece icon_evil.gif). The cables that I have seen from VAG so far have all been yellow and }did not} have individual wire insulation.
My preferred supplier still has (from whatever source) loose contacts available (for single-strand sealing), so I've been able to build all the cables exactly as I wanted them to be.
Best regards, Rudi.
Translated on 27-08-2026, 4:46.
Maik
Post28-11-2002, 11:27    Subject: Pump Connector Part Number: Find Yours Now! Quote
Okay, I'll just get the pre-cut cable lengths then.
Best regards, Maik.
Translated on 27-08-2026, 4:47.
No new posts Explanation of the VAG part number Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VP37 Pump Connector Pinout: Wiring Diagram Diesel Engine Technology
No new posts 98'AFN 8-ofor the 10-pin pump connector? Diesel Engine Technology
No new posts Motor läuft ohne Pumpenstecker... Diesel Engine Technology
No new posts STG Teilenummer MKB ASV Diesel Engine Technology
