28-04-2007, 23:34 Subject: Flexible 3C Closing Bolts |
HI.
I just filled up my Passat with gas and, of course, started fiddling with everything inside the car.
Is it normal for the latch bolt on the tailgate to be "spring-loaded"?
He's not completely secure, but also not so loose that it seems like it should be bombproof, and 1-2 screws are loose.
It's kind of weird.
Thank you.
m; Transparency, Teamwork
Translated on 18-09-2026, 11:48.
Profile PM Garage |
rubberduck Blaumann
30-04-2007, 10:49 Subject: Flexible 3C Closing Bolts |
Hi Martin,
It's probably because the 3C variant has a power-assisted opening mechanism for the tailgate. Wer Rechtschreibfehler findet, kann sie behalten !
Translated on 18-09-2026, 11:49.
02-05-2007, 9:43 Subject: Flexible 3C Closing Bolts |
Nope.
The assistance for installing the door is only available if it is a completely electric door.
I saved myself those 400 euros.
Profile PM Garage |
rubberduck Blaumann
02-05-2007, 17:13 Subject: Flexible 3C Closing Bolts |
I only read it while quickly skimming through the SSP, so I thought. Wer Rechtschreibfehler findet, kann sie behalten !
