Torque Measurement: Reading Data Blocks
acuransx
Karma: +1 / -1   Thank you, like it!
2002 Volkswagen Golf
Post04-05-2007, 16:31    Subject: Torque Measurement: Reading Data Blocks Quote
Hello everyone..., I've searched the forum but haven't found anything yet on this topic.
Can anyone tell me exactly how measurement block 20 (in a VW Golf IV) works?
I'm interested in seeing the torque displayed, but how does the control unit determine or calculate the torque? And how accurate is it? Or is it a different type of torque being measured? The text in this post doesn't provide enough information to determine whether this value is likely to be accurate.
Actually, it's a simple question that I can't seem to answer.
Translated on 02-10-2026, 20:08.
Malte1408
Post04-05-2007, 16:44    Subject: Torque Measurement: Reading Data Blocks Quote
MWB 20? What kind of engine are we even talking about?
Translated on 02-10-2026, 20:09.
acuransx
Post04-05-2007, 17:08    Subject: Torque Measurement: Reading Data Blocks Quote
I have an ASZ engine (now an ARL). However, my general concern is whether this can be considered accurate, as with other engine codes, the measurement block might be located in a different place.
Translated on 02-10-2026, 20:10.
Post04-05-2007, 17:28    Subject: Torque Measurement: Reading Data Blocks Quote
acuransx wrote:
I have an ASZ engine (now ARL). However, my general concern is whether this can be considered accurate, because with other engine codes, the measurement block might be located elsewhere.
It's a bit complicated. The displayed value doesn't account for internal friction or auxiliary components of the engine, so it's usually not very informative. You can tell this because the reading is already greater than zero even when the engine is idling.
No new posts Torque and driving fun in everyday life Technical Articles
No new posts Diagrams of Torque/Power with VCDS/VAG-COM Technical Articles
No new posts VAG 1.8L R4/5V 125hp (92kW) Naturally Aspirated Gasoline ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Performance chart - how to read? Diesel Engine Technology
No new posts Read CLB, use Dongle function On-Board Diagnostics (OBD)
No new posts Harmonic balancer from gasoline engine on TDI??? Please r... Diesel Engine Technology
No new posts AHF startup behavior now significantly improved! - read :-D Diesel Engine Technology
