Basti911 Guest
23-11-2002, 19:23 Subject: Timing belt width. |
Today, I measured the width of the timing belt on my Passat 1Z, and it came out to be 24 mm.
According to my repair manual, if the belt is wider than 22mm, it must be replaced.
Is that correct, and if so, how can the belt become wider?!?!
Or did I just misread something?
Best regards, BASTI!
Bertil Profi-Schrauber
23-11-2002, 19:42 Subject: Re: Timing belt width. |
Basti911 wrote: | I measured the width of the timing belt in my Passat 1Z today, and I got a measurement of 24 mm.
Best regards, BASTI! |
I think you mean narrower, like 22mm – that's the wear limit for the timing belt.
However, I believe that's probably the point where it's definitely time to act. Gruß Bertil
Basti911 Guest
24-11-2002, 14:33 Subject: Timing belt width. |
I just checked the book again:
'There it literally says:'
'If the width of the timing belt exceeds 22mm, it must be replaced.'
The book is called: 'This is how it's done!'
24-11-2002, 16:43 Subject: Timing belt width. |
Basti911 wrote: | I just checked the book again:
"There it literally says:"
"If the width of the timing belt exceeds 22mm, it must be replaced."
The book is called: "This is how it's done!" |
Hi.
and if the wax candles on the Advent wreath have grown by more than 50%, you must return them to the store  .
It shouldn't be taken to mean that I doubt the words of your book quote  .
However, a timing belt for a TDI engine doesn't actually get wider; it only gets narrower (and only if there's something wrong with the gear geometry!). Gruß Ulf
Profile PM Garage |
Basti911 Guest
24-11-2002, 20:58 Subject: Timing belt width. |
Well, if someone also has the book 'So wird's gemacht' by H.R. Etzold, they can read about it on page 42, in the lower right corner!
I'm curious to see what happens...
haehnlein Schrauber
Joined: 08/22/2002 Posts: 877 Karma: +6 / -0 Location: Griesheim
24-11-2002, 22:34 Subject: Timing belt width. |
Hi!
I also have the "How-to" guide for the Passat 35. It's totally awful! Some information is incorrect or missing, and there is no comparison to older generations.
Best regards, Christian.
Basti911 Guest
25-11-2002, 16:59 Subject: Timing belt width. |
Well, I was just wondering how a timing belt could possibly get wider...
Is there any other measurable wear limit?
haehnlein Schrauber
25-11-2002, 18:35 Subject: Timing belt width. |
Just to be on the safe side, replace this poorly designed part (tensioner pulley, idler pulley) every 60,000 km, and be sure to replace the tensioner and idler pulleys together! Check the intermediate shaft seal (I replace it every time) and, most importantly, check the axial play of the driveshaft on the VP37 ESP (wear limit 0.3 mm -> if greater, replace the bearings)!
