Fuel Injection Limit / Torque Optimization
jenseden
Post02-12-2002, 19:19    Subject: Fuel Injection Limit / Torque Optimization Quote
Hello everyone,
Why is the fuel injection limit so significantly below the driver's desired performance, or what driving parameters does this value depend on (see diagram)? I'm particularly surprised by the decreasing trend. Can anyone explain this?
How does the engine control unit (ECU) actually determine the torque (using a sensor or pre-calculated values from other driving parameters)?
http://www.informatik-consulting.de/kunden/VAG-COM/Spritzmenge-30-11-02.gif
Translated on 28-10-2026, 2:39.
Post02-12-2002, 21:25    Subject: Torque Limiting: Explained & Benefits Quote
Hi Jens,
The torque limitation is not based on the actual torque in each specific case, but rather on a standard profile that ensures the motor and powertrain are not overloaded.
Perhaps a term like "maximum load capacity under optimal conditions" would be more accurate.
The slight downward slope might have something to do with exhaust temperatures or something like that...??
Translated on 28-10-2026, 2:40.
No new posts Torque and driving fun in everyday life Technical Articles
No new posts Diagrams of Torque/Power with VCDS/VAG-COM Technical Articles
No new posts VAG 1.8L R4/5V 125hp (92kW) Naturally Aspirated Gasoline ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Boost Pressure Issues: Logs and Analysis Upload
No new posts VAG-COM 306.0 error messages regarding. TDI Timing / VAG-... Diesel Engine Technology
No new posts Biodiesel Damage: VW's Outrageous Response Diesel Engine Technology
No new posts Torque Diesel Engine Technology
