Hmm...
I emailed it to the address you provided (
[email protected]), and I haven't received anything back yet.
Pin 1 signal, rule slider position sensor, G149, reference coil.
Pin 2 'Power Supply' potentiometer G149.
Pin 3 signal, control slide, G149 measurement coil.
Pin 4: Sensor ground.
Pin 5 supply, N146 (quantity control).
Pin 6 controls N146 (flow control valve).
Pin 7: Fuel temperature signal, sensor G81.
Pin 8: Fuel shut-off valve control (N109).
Pin 9 controls N108 (fuel injection start valve).
Pin 10 supplies voltage to N108 (fuel injection start valve).
Best regards, Rudi.
