Speedometer Calibration: Accurate & Reliable
Hoin
Post26-11-2002, 21:16    Subject: Speedometer Calibration: Accurate & Reliable Quote
Can anyone tell me if it's possible to change the speedometer reading using the VW diagnostic tool (1551)?
Unfortunately, after installing a TDI PD engine (ATD, year 2000) in my T3 van, I don't have a working speedometer.
The Hall sensor and speedometer from a Golf IV, as well as various other components from the donor vehicle, have been installed. The sensor is connected to the speedometer shaft. The displayed speed is exactly 50% lower than the actual speed.
A factor needs to be modified to double the incoming signal.
Best regards, Hoin.
Düsen nicht dümpeln!!!
Translated on 28-09-2026, 18:32.
Back to top Profile PM Email
Michael II
Post26-11-2002, 21:25    Subject: Speedometer Calibration: Accurate & Reliable Quote
Could you please provide the part number of the combined device? That way, we can look it up.
Tschüss
Michael II
Translated on 28-09-2026, 18:33.
Hoin
Post27-11-2002, 9:35    Subject: Speedometer Calibration: Accurate & Reliable Quote
Hello Michael,
I don't have any diagnostic tools, so I can't give you a number.
The possibility of programming the software was suggested to me by an electrical engineer.
I'm not familiar with using tools like VAG-COM or software like 1551.
Best regards, Hoin.
Translated on 28-09-2026, 18:34.
eike
Post27-11-2002, 12:09    Subject: Speedometer Calibration: Accurate & Reliable Quote
The thing about the 50% display isn't that bad. You can quickly calculate how fast you are.
Does the odometer at least work, even if it's only half as fast?
Eike.
Translated on 28-09-2026, 18:35.
Hoin
Post27-11-2002, 20:10    Subject: Speedometer Calibration: Accurate & Reliable Quote
"You're right, Eike, the odometer is also only showing half the correct mileage."
The other values, such as fuel consumption, average speed, and distance traveled, are also incorrect.
Hi.
Uwe
Post02-12-2002, 22:02    Subject: Speedometer Calibration: Accurate & Reliable Quote
Hi!
Under http://ha-projekt.de/, you can buy a frequency doubler for 49,- €.
Uwe
Translated on 28-09-2026, 18:36.
No new posts Speedometer Calibration VW Polo 6N Diesel Engine Technology
No new posts Speedometer calibration with larger wheels??? Transmission, Chassis, Body & Interior
