GT1749VA: Remapping for Performance Gain
Mr Propper
Post07-06-2007, 21:34    Subject: GT1749VA: Remapping for Performance Gain Quote
I drive a Passat 3B 1.9 TDI (AFN) and I've just installed a GT1749VA turbocharger. My question is, what software values need to be adjusted to effectively utilize the performance of this turbocharger? Does anyone have a table or chart for this?
Best regards, Mr. Propper.
Translated on 01-09-2026, 23:44.
Rudi
Post07-06-2007, 22:23    Subject: GT1749VA: Remapping for Performance Gain Quote
Hi!
The software of the engine control unit needs to be modified, which is known as chip tuning.
There are people who sell things like that and make a living from it.
Rudi
Translated on 01-09-2026, 23:45.
Mr Propper
Post07-06-2007, 22:33    Subject: GT1749VA: Remapping for Performance Gain Quote
I already have a chip, but isn't it also possible to reprogram specific parameters individually? For example, increasing the turbo boost pressure, etc.?
Translated on 01-09-2026, 23:46.
Rudi
Post07-06-2007, 22:36    Subject: GT1749VA: Remapping for Performance Gain Quote
I already have a chip, but can't you also reprogram individual parameters specifically? For example, increasing the turbo boost pressure, etc.
If you know where they are located and are also able to calculate the checksums...
to correct - yes.
Rudi
Mr Propper
Post07-06-2007, 22:40    Subject: GT1749VA: Remapping for Performance Gain Quote
I believe my tuner knows what they're doing, but I'm wondering how much of a difference it will actually make in terms of performance and efficiency. The chip I'm currently using is probably tuned for a GT15 turbocharger.
Translated on 01-09-2026, 23:47.
Rudi
Post07-06-2007, 22:51    Subject: GT1749VA: Remapping for Performance Gain Quote
Your tuner should be able to answer those questions, as it should have the necessary information.
what he programmed and what condition your car is in.
If he can't do that, you might have a problem because you might need to revise something.
It's a very unrewarding job.
Rudi
No new posts GT1749VA: Max. Boost Pressure Diesel Engine Technology
No new posts Abgastemperatursensor GT1749VA On-Board Diagnostics (OBD)
No new posts VNT17 Turbo: Price & Specs Diesel Engine Technology
No new posts Garrett GT1749VA: Installation Questions & Help Diesel Engine Technology
