Engine won't start, cranks after start attempt (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post15-04-2002, 16:40    Subject: Engine won't start, cranks after start attempt Quote
1.9L direct injection engine.
AHU, AFN, AEY
Engine won't start.
The error sometimes occurs sporadically.
Cause:
Power supply relay for the motor control unit is defective.
Solution.
Testing the voltage supply of the engine control unit.
In case of a defect, replace the relay.
1.9 l SDI/TDI
AFN, AHU, AEY, AGD, ALE
Engine revs up to approximately 2,000 RPM after starting, experiencing a lack of power.
Approximately 120 km/h with error code 1237, fuel valve N109.
Warning light flashing.
Cause:
The electromechanical shut-off valve is used in the safety self-diagnosis system.
identified as defective.
Solution:
Repair of the electromechanical shut-off valve using the...
Part number 028 198 135.
Post15-04-2002, 20:58    Subject: Re: Question about the parking issue Quote
Hi Michael,
1.9 l SDI/TDI
Please provide the German text you would like me to translate into English.
Cause: The electromechanical shut-off valve is triggered during the safety self-diagnosis.
Series: Modified shut-off valves.
From 04.98.
Part set 028 198 135.
Do you also know the cause of the "defect detection"? For example, I could imagine a coil resistance falling outside the tolerance range stored in the motor control unit.
But if the engine still starts, then it can't be a "real" defect. Does the EDC also detect if the device doesn't close properly?
Otherwise: great idea with the "insider documentaries"! icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
Jan6K
Avatar-Jan6K
Post15-04-2002, 21:14    Subject: Collection? Quote
I fully agree with Ulf's statement - a great idea!
@Rainer: Perhaps we should try to compile this information in a concise manner, provided there are no legal objections, because for many common questions (e.g., the shaking when idling), a brief reference would suffice.
Jan.
Michael II
Post16-04-2002, 8:19    Subject: Re: Causes Quote
Hello Ulf,
Unfortunately, I am not aware of the exact causes either. Mine.
It is believed that the system checks the current flow when the valve is activated.
Therefore, it is quite possible that the winding values are outside the...
Tolerance or very close to it.
Michael.
Ratings - Engine won't start, cranks after start attempt
Average rating: 4.50 - worst rating: 4 - best rating: 5 - number of ratings: 2 - View ratings
No new posts Motor dreht hoch nach Warmstart Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Won't Rev Up: Troubleshooting & Fixes Diesel Engine Technology
No new posts Motor dreht bei Warmstart zu hoch !! Diesel Engine Technology
No new posts DPF Smoke: Passat 3C Engine Revving Issues Diesel Engine Technology
No new posts Engine won't start - after PDE replacement Diesel Engine Technology
