Document: PD Motor Stalling When Accelerating, Tandem Pump (Solution)
Post02-05-2002, 13:47    Subject: Document: PD Motor Stalling When Accelerating, Tandem Pump Quote
All pump-nozzle engines, experiencing vibrations when accelerating.
Cause:
Insufficient fuel supply pressure. Pressure limiting valve in the auxiliary pump is not closing.
Solution:
If the target value is not reached, ensure that the filter unit and check valve are unobstructed. Second pressure supply without the filter unit and check valve. If the target value is still too low, replace the tandem pump. Otherwise, the cause lies in the fuel supply.
Test Tandempumpe bei TDIs mittels folgender Prüfung:
Measure the pump outlet pressure using a pressure gauge (VAG tool), for this, unscrew the clamping screw of the measuring connection (when viewing the pump from the front, on the left side and below, above the return connection). Pressure requirement, e.g., for the ASZ at 1500 rpm: at least 3.5 bar.
If the target value is not achieved, clamp the return line before the diesel filter. If the target pressure is then achieved, clamp the O-rings of the PDE between the inlet and return (= the 2. (Ring from above) - at least partially defective -> replace.
Will the delivery pressure also be achieved with a reduced return flow -> Replace the pump.
Author: Michael II
Ratings - Document: PD Motor Stalling When Accelerating, Tandem Pump
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 2 - View ratings
No new posts Document, 2.5 l, 6-cylinder / Jerking/Hesitation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku V6 TDI AKE/AYM - Jerking and Lack of Power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1K1 DPF, BAG to week 35.04, misfire at approximately... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Caddy 2K Engine: Black Smoke When Accelerating Diesel Engine Technology
No new posts R5 TDI VW Touareg: White/Blue Smoke When Accelerating Diesel Engine Technology
No new posts Passat Engine Jerk: Troubleshooting & Repair Diesel Engine Technology
No new posts Rough idling when accelerating; incorrect PD element?? Diesel Engine Technology
