Spark Plug Winder Repair: Get Help Now!
haehnlein
Post14-10-2002, 11:47    Subject: Spark Plug Winder Repair: Get Help Now! Quote
Hi fellow DIY enthusiasts!
I was just about to change my glow plugs, and I can't get the one on the infamous 3rd cylinder out. The spark plug turns, but it won't go in or out! Now I'm probably really frustrated. How can I get that thing out? Are there any special tools for this? What can be done about the damaged thread (can it be re-tapped? -> but surely no metal shavings can get into the cylinder)? This is how my dream of driving a TDI is starting... I wish I had just kept my Passat TD from 1985 with 330,000 km... "wail". icon_sad.gif
Translated on 28-10-2026, 13:29.
haehnlein
Post14-10-2002, 11:49    Subject: Spark Plug Winder Repair: Get Help Now! Quote
Okay: Passat TDI, year 1995, engine 1Z, 174,000 km.
Thank you in advance.
Translated on 28-10-2026, 13:30.
Post14-10-2002, 13:05    Subject: Retap Threads: How to Fix Stripped Screw Holes Quote
I once re-tapped the spark plug threads in the head and used a "HELICOIL" insert to re-install the spark plug. The threads are cut with a very generous amount of grease so that the metal shavings don't fall uncontrolled into the engine and remain on the tap.
I can't tell you if that's possible with a TDI engine, but it's certainly something to consider.
haehnlein
Post14-10-2002, 13:48    Subject: Spark Plug Winder Repair: Get Help Now! Quote
Hi Bertil!
Thank you for the quick response! The problem is, how do I get the old spark plug out? With the limited space, it's difficult to apply enough force to the part. I can already see that I might have to remove the cylinder head.
Translated on 28-10-2026, 13:31.
Post14-10-2002, 20:42    Subject: Spark Plug Winder Repair: Get Help Now! Quote
Hello Christian,
If you also try to shoot the part out using compression pressure from the running engine? A thick cloth or a clear flight path (without your own head getting in the way icon_wink.gif) should prevent dents in the hood or your head.
Translated on 28-10-2026, 13:32.
haehnlein
Post14-10-2002, 21:32    Subject: Spark Plug Winder Repair: Get Help Now! Quote
Hi Rainer!
Das hab ich mir auch schon überlegt. Das Problem ist aber, dass über dem Glühkerzengewinde noch 5mm Gewinde im Zyko sind. Außerdem habe ich schon bei dem Gedanken daran die Hosen gestrichen voll icon_eek.gif Muss mich wahrscheinlich damit abfinden den Zyko rauszuschrauben. VieYou're welcome.
Best regards, Christian.
Translated on 28-10-2026, 13:33.
haehnlein
Post15-10-2002, 21:25    Subject: Spark Plug Winder Repair: Get Help Now! Quote
Hi!
Today, I found a pretty cheap offer on motorensuche.com for the installation of a Helicoil thread insert... so, I went out into the rain and removed the cylinder head icon_lol.gif.
haehnlein
Post01-12-2002, 16:48    Subject: Spark Plug Winder Repair: Get Help Now! Quote
Hi!
Ugh, that was a difficult process! After 5 weeks and involving a lawyer, I finally received my cylinder head back from www.motorensuche.com, and of course, it wasn't repaired!!! They lied to me the entire time. Of course, there are also good companies out there, like www.motorinstandsetzung-christmann.de! They managed to repair it in just 2 days!
Translated on 28-10-2026, 13:34.
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document MKB AKQ, defective timing belt tensioner Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Head Gasket Failure: Get Help Now! Diesel Engine Technology
No new posts Turbo Problems? Get Turbo Repair Help Now! Diesel Engine Technology
No new posts Climatronic Malfunction: Get Help Now! On-Board Diagnostics (OBD)
No new posts KEY-USB Interface Failure: Short to Ground? On-Board Diagnostics (OBD)
