00575 - Intake manifold pressure: What could it be?
peterchen1976
Post25-06-2007, 7:49    Subject: 00575 - Intake manifold pressure: What could it be? Quote
Hello everyone,
I'm having a problem with my T4 (2.5L R5, 102 hp).
I noticed that it exhibits a loss of power above a certain RPM.
Okay, I connected the VAG-COM and read the following error message.
Control unit part number: 074 906 021 L.
Component and/or version: 2.5L R5 EDC G00SG 1450
Encoding: 00002
Workshop code: WSC 02744.
"1 error found:"
00575 - Intake manifold pressure.
17-10 - Rule difference - Sporadically.
He doesn't emit any smoke, everything seems normal. In the first, second, and third gears, I shift up slowly in the fourth gear, and suddenly, the power just cuts out.
There's no whistling sound from a damaged hose or anything like that.
What could it be?
With best regards,
Rudi
Post25-06-2007, 8:02    Subject: 00575 - Intake manifold pressure: What could it be? Quote
N75
Otherwise, use the search function.
No new posts Document: Performance Drop, Error 00575, V6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document error 00575 with full throttle, AKN and AFB engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
No new posts TDI AHU; 00575 - Intake manifold pressure regulation diff... On-Board Diagnostics (OBD)
No new posts Intake Manifold Pressure Differential Regulation Diesel Engine Technology
No new posts 1Z 00575: Low Intake Manifold Pressure - Troubleshooting On-Board Diagnostics (OBD)
No new posts Audi AFB `98: P0113 - Low Intake Manifold Pressure Diesel Engine Technology
