Controller Login Code
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Tins
Post06-07-2007, 18:54    Subject: Controller Login Code Quote
Hello, I have a problem. I would like to enable the cruise control. I have VAG Com version 311.... Where can I find it so that I can enable the cruise control? I have a control unit from 1Z. I also don't know the code to access the engine electronics. Can anyone help me?
Thank you in advance.
Best regards, Tins
mullemaus
Post06-07-2007, 19:47    Subject: Controller Login Code Translating...
[Translating...]Hast Du dazu mal im Board gestöbert? Es sollten die Aktivierungscodes für den Tempomaten zu finden sein. Die Suche ist Dein Freund icon_wink.gif
No new posts Login Codes TDI / VAG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS-Steuergerät 6X0 907 379B - Fehlercode 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Login-Code für Komfortsteuergerät Diesel Engine Technology
This topic is locked, you cannot edit or reply. Suche 7-Stelligen Login-Code On-Board Diagnostics (OBD)
No new posts Login Code AEL Motor z.B. für Startmenge On-Board Diagnostics (OBD)
No new posts Suche Login Code für Komfortsteuergerät On-Board Diagnostics (OBD)
