Linear Lambda Sensor: What You Need to Know
luiggi
Post10-07-2007, 20:16    Subject: Linear Lambda Sensor: What You Need to Know Quote
Can someone explain to me what a "linear probe" is? I have two probes installed in my BGU engine (in an Audi A3), one before the catalytic converter and one after it.
Does the term "linear probe" refer to both probes in general, or only to one of them?
It's showing me two error codes:
17 589 Linear lambda sensor - Warning light ON.
and
Bank 1, Sensor 1.
What is meant by that: before "KAT" or after "KAT"?
Translated on 25-07-2026, 5:08.
doppelteglasur
Post10-07-2007, 20:42    Subject: Linear Lambda Sensor: What You Need to Know Quote
Linear lasers are broadband probes consisting of a measurement cell and a pumping cell.
The broadband probe allows for the continuous measurement of Lambda values between 0.8 and 2.5.
These probes are installed as pre-catalyst sensors.
Translated on 25-07-2026, 5:10.
No new posts Lambda Values: Definition & Regulations Technical Articles
No new posts P0170 - Fuel Mixture Control (Oxygen Sensor Circuit Malfu... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts O2 Sensor for V6 TDI 3.0/2.7: Which one? Diesel Engine Technology
No new posts 3.0 TDI Problems: Lambda Sensor/Oxygen Sensor Diesel Engine Technology
No new posts 1.4 TDI: Faulty EGR Valve & O2 Sensor? Diesel Engine Technology
No new posts Audi A2 8Z AUA Engine Lambda Sensor Gasoline Engine Technology
