DPF Smoke: Passat 3C Engine Revving Issues
Bolzer
Karma: +14 / -0   Thank you, like it!
Post19-07-2007, 22:59    Subject: DPF Smoke: Passat 3C Engine Revving Issues Quote
Hi.
I have two problem vehicles. One is an A4 ADR model. Apparently, the A4 revs up to the limiter. I've been driving the A4 for 100km and haven't been able to reproduce the issue yet. According to the report, it always happens when releasing the accelerator, so I initially thought it might be a stuck throttle body or a problem with the gas cable. However, I found nothing. Today, I cleaned the throttle body and adjusted its basic setting. So far, everything seems okay. What I've noticed is that the load indicator only goes up to 85.9%. I'm not reaching 100%. Could it be a faulty throttle position sensor? Can this be readjusted, or do I need a new throttle body? What else could explain or cause the high revving?
Okay, let's talk about the Passat. My brother-in-law has a 3C model with a 170 hp engine and a DPF (Diesel Particulate Filter). The Passat occasionally produces very strong blue smoke with a pungent odor. I believe this is caused by the DPF.
"I haven't had the car yet, so I don't have any measurements. The dealer said that the smoking is normal. What I don't think is normal is the white/blue haze that appears behind the car while driving. How can I check the filter system, or are there any known issues that could be causing problems with the DPF?"
Best regards, Bolzer.
Translated on 31-07-2026, 21:40.
Post20-07-2007, 10:40    Subject: DPF Smoke: Passat 3C Engine Revving Issues Quote
There was also a report of a smoking BMR (battery management system) in the 3C on Spritmonitor.de.
He then exchanged it.
Mine doesn't do that...
Translated on 31-07-2026, 21:42.
Bolzer
Post20-07-2007, 17:13    Subject: DPF Smoke: Passat 3C Engine Revving Issues Quote
Hi.
Thanks for the tip. I sent him an email. Let's see what happens.
Translated on 31-07-2026, 21:43.
tdi pumpe düse
Post20-07-2007, 18:33    Subject: DPF Smoke: Passat 3C Engine Revving Issues Quote
Please be friendly and install the new update.
Bolzer
Post20-07-2007, 23:02    Subject: DPF Smoke: Passat 3C Engine Revving Issues Quote
Hello Lars,
We've already installed the update. However, this issue only started appearing long after the update was installed.
Bolzer
Post23-07-2007, 12:53    Subject: DPF Smoke: Passat 3C Engine Revving Issues Quote
Hi.
Okay, so the A4 is fixed. The problem was that several hoses located under the intake manifold were damaged/porous and cracked. Also, the plastic parts of the crankcase ventilation system were broken. However, the actual underlying issue didn't manifest itself in my case.
The Passat:
"@Dieselmartin. Even with the part that was replaced, the workshop said that this is normal."
Let's see how things develop. I'll keep you updated.
Translated on 31-07-2026, 21:44.
No new posts Engine Revs High After Warm Start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine won't start, cranks after start attempt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Passat, Model Year 2000, Window Seal is Raised/... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Revs High on Warm Start? Diesel Engine Technology
No new posts Engine Won't Rev Up: Troubleshooting & Fixes Diesel Engine Technology
No new posts TDI Engine: Troubleshooting & Solutions Diesel Engine Technology
No new posts Engine RPM Limited to 3000, Excessive Smoke Diesel Engine Technology
