TDI: The Ultimate Guide
Zwewwel
Post05-07-2007, 10:48    Subject: TDI: The Ultimate Guide Quote
Hello everyone,
'My VW Passat 1.9 TDI (engine code: 1Z, year: 1995) is making a knocking sound, as if the hydraulic lifters are defective. I've already replaced the cylinder head with the camshaft and lifters, but it hasn't made any noticeable difference. The engine starts without any problems and doesn't have any loss of power while driving. There's no smoke and the error memory is also empty.'
I'm at my wit's end; who can help me?
Translated on 03-10-2026, 21:40.
Boro
Post05-07-2007, 10:55    Subject: TDI: The Ultimate Guide Quote
Check the injection pump's start of injection! If the injection timing is too early, a TDI engine will make a significant knocking noise...
Possibly, the pump is misadjusted!
Post05-07-2007, 13:32    Subject: TDI: The Ultimate Guide Quote
How old are the nozzles?
Translated on 03-10-2026, 21:41.
Zwewwel
Post05-07-2007, 16:25    Subject: TDI: The Ultimate Guide Quote
The injectors are about 6 years old, but I had them tested by a Bosch service today. The spray pattern and injector opening pressure (185 - 195 bar) were okay. Tomorrow, I'm going to try swapping the injectors with a set from another Passat 1.9 TDI (same model, same engine) and see if there's any difference.
Malte1408
Karma: +12 / -0   Thank you, like it!
Post05-07-2007, 16:48    Subject: TDI: The Ultimate Guide Quote
Just check the start of the injection process first; it's a 5-minute thing, including booting up the laptop.
Translated on 03-10-2026, 21:42.
Zwewwel
Post14-07-2007, 12:55    Subject: TDI: The Ultimate Guide Quote
We checked and readjusted the injection system yesterday. At the same time, I noticed that the engine runs smoothly from approximately 2300 RPM. Even a friend who works at the dealership doesn't have any answers.
No new posts Rebuilt Engine Misfire: Causes & Fixes Diesel Engine Technology
No new posts Engine knocking, 140hp 2.0 TDI with DPF (BMM) Diesel Engine Technology
No new posts Loud TDi engine (81 kW) and excessive fuel consumption Diesel Engine Technology
No new posts G4 1.6 FSI knocking shortly after start? Gasoline Engine Technology
