Touran: Change Service Interval - Easy Guide
winschi
Post15-03-2008, 21:34    Subject: Touran: Change Service Interval - Easy Guide Quote
Hello!
Can someone tell me how to change my service interval using VAG-COM?
It's completely new territory for me icon_wink.gif.
I would like to reduce the service interval from 30,000 km to, for example, 20,000 km.
mfg
winschi
Translated on 24-09-2026, 15:01.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post15-03-2008, 21:42    Subject: Touran: Change Service Interval - Easy Guide Quote
Hello Winschi, searching for: Technical articles - Technical data - Service intervals for VAG - icon_idea.gif
edit: In my version, there's a great feature in the menu called "Service Reset."
The required channels 40...45 are automatically running.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 24-09-2026, 15:02.
winschi
Post15-03-2008, 21:53    Subject: Touran: Change Service Interval - Easy Guide Quote
"Thank you!"
But I don't quite understand how it all works yet.
The Touran is not listed in the table, but I assume it will be the same. icon_rolleyes.gif
I don't even know which channels I need to edit.
mfg
winschi
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post15-03-2008, 22:39    Subject: Touran: Change Service Interval - Easy Guide Quote
Wow, I need to connect to the VAG system and take notes first.
But if you've already switched to the fixed 15,000 km setting using the buttons on the instrument cluster...
Why actually 20,000? Either a fixed interval based on mileage, or an indicator for long-life service.
Translated on 24-09-2026, 15:03.
winschi
Post15-03-2008, 23:07    Subject: Touran: Change Service Interval - Easy Guide Quote
Yes, I've read through the service plan.
My Touran 1.9 TDI is due for its longlife service, and I want to schedule it.
15,000 km driven (confirmed by a sales representative).
That's enough for me, as I'm not a frequent driver.
As mentioned before, this is completely new territory for me, as I used to drive a Golf II until recently icon_lol.gif.
mfg
winschi
Translated on 24-09-2026, 15:04.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post16-03-2008, 6:52    Subject: Touran: Change Service Interval - Easy Guide Quote
The user manual explains how easy it is, so you don't even need to use LL oil.
certainly, but PD. 50501 5W40.
Translated on 24-09-2026, 15:05.
winschi
Post17-03-2008, 8:12    Subject: Touran: Change Service Interval - Easy Guide Quote
mfg
winschi
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post17-03-2008, 17:29    Subject: Touran: Change Service Interval - Easy Guide Quote
Here's the translation:
"Refer to your vehicle's owner's manual: Defer service reminder."
winschi
Post17-03-2008, 18:29    Subject: Touran: Change Service Interval - Easy Guide Quote
I have now reset the service using Vag-Com, but before resetting, channels 43 & 44 were available. After resetting, when I accessed the channels, I received the message: "Error not available" - icon_confused.gif icon_eek.gif WHY?????
mfg
winschi
Translated on 24-09-2026, 15:06.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post17-03-2008, 22:02    Subject: Touran: Change Service Interval - Easy Guide Quote
but you can still check later what's currently programmed, right?
Okay, for example, 15,000 and 360 days.
winschi
Post17-03-2008, 22:41    Subject: Touran: Change Service Interval - Easy Guide Quote
Yes, I can read that. I now see nothing on channels 43 & 44. I have reduced the time until the service from 744 to 360, and the maximum mileage to service on that channel from 300 (x100) to 150. I have also changed the oil quality from 2 to 1. icon_lol.gif
mfg
winschi
Translated on 24-09-2026, 15:07.
winschi
Post17-03-2008, 23:31    Subject: Touran: Change Service Interval - Easy Guide Quote
The current values are displayed after the reset. However, nothing is displayed on channels 43 and 44 anymore!
02 service reminder status..........................................0 _______0
40 miles since service... km x 100... 0 _______-
41 times serviced. ........................ Days ........................0 _______-
42 minutes mileage to service... km x 100... 150 ______-
43 maximum mileage to service.
44 max time so service.............. ..----.........................----_______-
45. Oil Quality.............................................................1 ________-
47 Soot Quantity........................km x 100...................0 ________-
48 thermal load..........................km x 100..................0 ________-
49 minimum service time... Days... 370...
mfg
winschi
Translated on 24-09-2026, 15:08.
serdarg
Post06-04-2008, 14:13    Subject: Touran: Change Service Interval - Easy Guide Quote
If you switch to a fixed interval, you no longer need to provide any values.
The days and the 15,000 km countdown are sufficient; all other values are then irrelevant.
Translated on 24-09-2026, 15:09.
No new posts Touran 1T: Fueling Problems & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Touran: GRA Disengagement Explained Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran: Transfer log files to laptop On-Board Diagnostics (OBD)
No new posts Touran 2.0 TDI: Engine Stalling Problems Diesel Engine Technology
No new posts SRA glued onto the Touran Transmission, Chassis, Body & Interior
No new posts Retractable Side Mirrors: Touran Aftermarket Installation Transmission, Chassis, Body & Interior
