Tachofolie: Incorrect Speed After Installation
Go to page: 1, 2  Next
fieserfettsack
Post19-07-2007, 11:27    Subject: Tachofolie: Incorrect Speed After Installation Quote
Hi everyone.
I purchased a speedometer overlay from Sport Edition, along with matching needles, and installed it. So far, everything is great; the appearance is unbeatable (except that the indicator for the high beam had to be taken from the old overlay...). Now, to the point: Unfortunately, where the 120 km/h mark was on my old speedometer (at the top center, approximately), it's now the 100 mark. This means that if I'm driving at 120 km/h, only 100 km/h is displayed. Is it possible to adjust this via OBD? If so, what exactly needs to be adjusted and how? I think it might have something to do with the K-value, right? How do I explain this to my mechanic? The speedometer itself is functioning correctly, it's just that the scaling is different, so it's a problem I created myself...
This is about a Volkswagen Golf IV Variant Highline with an 85 kW TDI engine, registered in January 2001, but with a head airbag system and integrated child seats, and therefore most likely a 2001 model.
It would be great if someone could help me.
Translated on 25-08-2026, 13:30.
mullemaus
Post19-07-2007, 18:32    Subject: Tachofolie: Incorrect Speed After Installation Quote
To achieve this, the characteristic curve in the speedometer must be changed from non-linear to linear. This cannot be done by a VW dealer icon_wink.gif.
Translated on 25-08-2026, 13:31.
fieserfettsack
Post19-07-2007, 19:06    Subject: SEO: Best Practices for Website Optimization Quote
Thank you...
But: Why linear and non-linear? And how can this be done? Or rather, WHO can do it?
Translated on 25-08-2026, 13:32.
mullemaus
Post19-07-2007, 19:18    Subject: Tachofolie: Incorrect Speed After Installation Quote
In one, the number 100 is located at the top center, and in the other, it says 130. icon_wink.gif
The first half is divided into equal parts (up to 100), while the second half is divided into shorter intervals. And in the standard version, the structure is completely the same icon_wink.gif.
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post19-07-2007, 19:30    Subject: Tachofolie: Incorrect Speed After Installation Quote
Hello.
You can send me your speedometer, and I'll load a different calibration curve or dataset onto it. What is the part number of your speedometer?
"MFG" is an abbreviation for "Mit freundlichen Grüßen," which means "Sincerely" or "Best regards" in English.
Audi SQ5 8R Cvub
Translated on 25-08-2026, 13:33.
Back to top Profile PM Email
fieserfettsack
Post20-07-2007, 19:11    Subject: Tachofolie: Incorrect Speed After Installation Quote
The part number is 1J0 920 845 C. Unfortunately, I can't ship the speedometer because I need it to drive.
Translated on 25-08-2026, 13:34.
fieserfettsack
Post27-07-2007, 9:48    Subject: SEO-Optimized: "Best [Produkt/Dienstleistung] - Find the Perfect [Produkt/Dienstleistung]" Quote
Are there any other ways to adjust this? And shouldn't it be adjusted from linear to non-linear, since the OLD scaling was uniformly from 0-260, and the NEW scaling is uneven?
mullemaus
Post27-07-2007, 18:00    Subject: Tachofolie: Incorrect Speed After Installation Quote
fieserfettsack
Post27-07-2007, 18:07    Subject: Linear vs. Nonlinear: Explained & Examples Quote
..and which way is correct now? Is the old one linear, and the SE non-linear?
Translated on 25-08-2026, 13:35.
mullemaus
Post27-07-2007, 18:16    Subject: Tachofolie: Incorrect Speed After Installation Quote
This is an 845.
http://www.gti-tdi.de/ebay/1J5920845C1.JPG
That's a normal...
http://www.gti-tdi.de/ebay/7D0920843B1.jpg
In principle, both the linear and non-linear versions look very similar when shifted. If you only change the slides, it's difficult to avoid adjustments. icon_wink.gif Find the appropriate one, and then we can say what works or what doesn't. icon_wink.gif
fieserfettsack
Post27-07-2007, 19:29    Subject: SEO: Best Practices for Website Optimization Quote
Okay, so far the pictures match my story. The lower one shows what my speedometer looked like before, and the upper one shows what it looks like now. As I said, my speedometer is a 1J0 920 845 C. However, it must be a niche model from the beginning of production, because I only have 6 symbols on one side. The newer ones have 8, as I've heard. So, the speedometer film is indeed appropriate for the age of my speedometer. However, it's not a Highline version like the rest of the speedometer, but an SE version.
I'm somehow stuck, but this thing should definitely display the correct speed.
Translated on 25-08-2026, 13:37.
fieserfettsack
Post27-07-2007, 19:31    Subject: Best German Restaurants: Find Top Rated Dining Quote
Me again...
I've noticed another difference: On the new sheet, there's an EPC symbol where the WFS symbol used to be.
Translated on 25-08-2026, 13:38.
mullemaus
Post27-07-2007, 21:54    Subject: Tachofolie: Incorrect Speed After Installation Quote
EPC simply means that this page was taken from a gasoline-powered speedometer. icon_wink.gif And to be clear, the only thing that will help you is a change in the dataset. icon_wink.gif You can talk about it for two more pages, but it won't get any better. icon_wink.gif
fieserfettsack
Post28-07-2007, 7:04    Subject: Tachofolie: Incorrect Speed After Installation Quote
...but the scale on the gasoline engine doesn't just go up to 5, does it??
Translated on 25-08-2026, 13:39.
Post28-07-2007, 12:16    Subject: Tachofolie: Incorrect Speed After Installation Quote
fieserfettsack wrote:
...but the scale on the gasoline engine doesn't only go up to 5, does it??
No.
mullemaus
Post28-07-2007, 15:27    Subject: Tachofolie: Incorrect Speed After Installation Quote
The scales are divided, so you will have a mix; you'll have the RPM scale for the diesel and the KM/H scale from the gasoline engine icon_wink.gif.
No new posts Misaligned Engine Mounts: Causes & Fixes Diesel Engine Technology
No new posts Speedometer calibration On-Board Diagnostics (OBD)
No new posts Speed sensor location: VW Golf B4 TDI 1Z (1993) Diesel Engine Technology
No new posts Glow Plug Installation: Did I Do It Right? Diesel Engine Technology
