Engine Control Unit (ECU) Differences
joergs
Post08-12-2002, 14:26    Subject: Engine Control Unit (ECU) Differences Quote
Hello everyone,
Can anyone tell me exactly what the difference is between VW-Nr.:
028 906 021 FB and 028 906 021 B are both engine control units (ECUs) for the 1Z engine. The former is supposedly from a Vento, while the latter is from a Passat. The connector was slightly different, but I sanded it down, and the Passat connector fits perfectly. I've already driven with it. The car feels slightly slower (or at least I think so!), and it produces more smoke under full load. But otherwise, it works perfectly!
I understand that the Vento will have different control unit parameters due to different gear ratios, etc. But how do those parameters affect the Passat? Apparently, on the Golf 3, this device has the side effect of increasing power output by about 10%, due to those different parameters.
You're welcome.
Jörg.
Translated on 21-10-2026, 19:37.
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ALH vs. AFN Motor Difference Diesel Engine Technology
No new posts ABS vs. Non-ABS JR Motor: What's the Difference? Diesel Engine Technology
No new posts Difference Between ASZ and ARL TDI Engine Diesel Engine Technology
This topic is locked, you cannot edit or reply. TDI vs. TD: What's the Difference? Diesel Engine Technology
