31-07-2007, 12:10 Subject: Air filter housing - a science in itself |
Wow,
I was quite surprised when I curiously peeked into the air filter box of my Passat yesterday.
Compared to the G3 TDI, it's a delicate masterpiece. What was particularly interesting was the "guide element" located directly in front of the filter, ensuring a uniform flow of air onto it.
G2 and G3 filters always had this "braking strip" on the dirty side, where the main flow of water entered... and that's where the dirt would accumulate.
The Passat has a very cleverly designed labyrinth before the filter, which ensures that water stays out.
The filter appeared to be only minimally (and, above all, uniformly) grayed after 14,444 km.
There was no getting rid of it, even with a beach vacation.
By the way, the spacer adhesive was also applied on the dirty side (and it was new, compared to...). G3) Once broken, likely during the improper installation of the filter.
Profile PM Garage |
haithamina Schrauber
Joined: 05/15/2006 Posts: 666 Karma: +27 / -3 Location: 69221 Dossenheim
Albrecht likes this. |
31-07-2007, 12:31 Subject: Air filter housing - a science in itself |
That's interesting. Is there a picture?
I am unable to translate "haithamina" because it does not appear to be a word or phrase in the German language. It may be a misspelling, a proper noun, or a term from a specialized field. If you can provide more context or clarify the intended meaning, I would be happy to assist you with the translation.
christians Profi-Schrauber
31-07-2007, 12:44 Subject: Air filter housing - a science in itself |
These grilles were invented for the V6 TDI engine to address the issue of mass airflow sensor (MAF sensor) failures.
Gruß Christian
31-07-2007, 13:25 Subject: Air filter housing - a science in itself |
I'd be happy to take some photos.
I just didn't have the camera attached at the moment, and I can always remove those eight screws again.
Is 7 MP resolution enough?
Profile PM Garage |
31-07-2007, 13:31 Subject: Air filter housing - a science in itself |
Did V6 LMM failures occur due to a long ECU warm-up time and backflowing oil vapor?
Profile PM Garage |
31-07-2007, 15:57 Subject: Air filter housing - a science in itself |
"7 MP is already quite a lot. I just want to be able to recognize it." That's enough, thank you!
01-08-2007, 12:42 Subject: Air filter housing - a science in itself |
Oil fumes and afterburning have been A problem, but the V6, as a test platform, has had several...
According to the technical article, which likely draws on a TPL (Technical Product Literature), the snow grid of the Nordic versions was initially recommended as a solution. It will basically be the same as your maze.
Gruß Christian
06-08-2007, 10:42 Subject: Air filter housing - a science in itself |
Here's a photo of the distribution manifold BEFORE the filter in the 3C.
| Description: |
| File size: |
67.7 KB |
| Viewed: |
1479 times |
Profile PM Garage |
06-08-2007, 11:09 Subject: Air filter housing - a science in itself |
Hm,
Can you please elaborate on that with a few more sentences? Does the air come from the top? And where does it go? This grid on the upper left is open and leads into the engine compartment, towards the battery? You're welcome.
06-08-2007, 11:48 Subject: Air filter housing - a science in itself |
Sure, here's the translation:
"Here is the whole thing, written in a very verbose and elaborate style."
The airflow comes from (in the image, from the bottom) the front and goes into the engine compartment.
In the first chamber, a portion of the air is "skimmed off," while the rest exits through the back and bounces off the air-fuel ratio sensor. Here, water droplets sometimes pass straight through and are thus filtered out.
Then a large, curved section goes downwards and connects to the air filter housing at the bottom.
Then we'll go upstairs to the LMM.
The pipe leading to the mass airflow sensor initially connects to a box that also has something to do with air, but I don't understand why a dead space was created on the dirty side – perhaps to reduce noise.
| Description: |
| File size: |
81.65 KB |
| Viewed: |
1237 times |
Profile PM Garage |
06-08-2007, 12:31 Subject: Air filter housing - a science in itself |
Aha! Okay, now it's becoming clearer. And the filter sits horizontally on this grid, as you can see in the first picture, right? Hmm, it looks nice! Not much water will reach (and pass through) the filter.
