Ford Focus: Check Engine Light & Error Codes
andi1281
Post10-08-2007, 18:18    Subject: Ford Focus: Check Engine Light & Error Codes Quote
hello
I currently have a Ford Focus, model year 2004, with a 1.8 TDCi engine, and I want to swap it with my VAG car.
Check error codes.
That won't work.
What am I doing wrong, or is there a problem with Vag?
Andy
Translated on 20-10-2026, 5:53.
alsch
Post10-08-2007, 21:19    Subject: Ford Focus: Check Engine Light & Error Codes Quote
Hello.
The name VAG-COM comes from Volkswagen and Audi, Ford is a different corporation, and also uses a different protocol with different pins for data transmission (PWM according to ISO 1850). VAG uses ISO 9141. Through the OBD2 interface, data can only be read if this protocol is also supported.
alsch
Translated on 20-10-2026, 5:54.
bastion
Karma: +6 / -1   Thank you, like it!
Post10-08-2007, 23:06    Subject: Ford Focus: Check Engine Light & Error Codes Quote
With the current VAG-Com version, it is possible to read data regardless of the manufacturer via OBD2. Which version do you have?
A4 Avant 08/01 AWX 05/08-
Translated on 20-10-2026, 5:55.
alsch
Post11-08-2007, 11:04    Subject: Ford Focus: Check Engine Light & Error Codes Quote
"With the current VAG-Com version, it is possible to read data independently of the manufacturer via OBD2"
Not quite. As mentioned, Ford uses a different protocol via different pins (I believe pins 2 and 10), so it only works with OBD2 interfaces if they support ISO1850 in addition to ISO9141, which VAG-COM cannot do.
Ford vehicles from 2004 often also use a CAN-bus system for diagnostics. I'm unfortunately not sure how VAG-COM OBD2 works with that. It might be possible to use a Hex-Can interface – maybe. I'll try it out next time I get my hands on a Ford with CAN, but I haven't had many of those yet.
Translated on 20-10-2026, 5:56.
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Ford Focus 1.6 TDCi - Error code P1181 General Tips
No new posts Ford Fiesta Temperature Sensor: Problems & Fixes General Tips
No new posts ECU Diagnostics Toledo 1M TDI On-Board Diagnostics (OBD)
No new posts Check Remaining Mileage Flexible Service Interval On-Board Diagnostics (OBD)
No new posts OBD2 Check via Internet: Permanent Password Query On-Board Diagnostics (OBD)
No new posts Error memory 1Z-TDI Diesel Engine Technology
