1.9 TDI PD Glow Plugs: Replacement & Info
luebby1
Post08-12-2002, 11:48    Subject: 1.9 TDI PD Glow Plugs: Replacement & Info Quote
Okay, since the 1.9 TDI engine has glow plugs that heat up the coolant starting at 5°C, I have a few questions about that.
How many watts does each one have?
2. Can I reprogram the engine control module (ECM) using the diagnostic connector to make it start heating at an intake air temperature of around 10°C? If so, how?
Translated on 02-10-2026, 3:54.
Post08-12-2002, 14:29    Subject: 1.9 TDI PD Glow Plugs: Replacement & Info Quote
Hi.
The wattage, which represents the power consumption, is temperature-dependent.
When cold, with a resistance of approximately 0.1 ohms, these devices initially draw roughly 1.5 kW each.
As far as I know, they are still consuming around 150-200 watts each.
Reprogramming is not possible with the AFN model, and it's likely the same for all other models as well.
Translated on 02-10-2026, 3:55.
luebby1
Post08-12-2002, 19:44    Subject: 1.9 TDI PD Glow Plugs: Replacement & Info Quote
Then I'll inquire further to see if it might be possible to reprogram it after all.
If it doesn't work, I can still give them a good jolt with an external voltage icon_smile.gif.
Thank you for your reply.
Translated on 02-10-2026, 3:56.
No new posts Auxiliary heating - glow plugs or similar. Diesel Engine Technology
No new posts Spark Plug Test - 11V? Diesel Engine Technology
