Only 8 volts on the N75, is that normal???
flightmaster
Post14-09-2007, 19:56    Subject: Only 8 volts on the N75, is that normal??? Quote
Golf 4, Year 1999, Alh, 203000km, everything original....
Hello everyone,
I came across some documents about fuel converters on the Pierburg website while browsing the internet today. There was information on how they work and also how to check them.
Then I measured the voltage at the connector with the 'ignition' switched on... it was only 7.5 volts icon_eek.gif. Instead of the expected 12V. 'Then, even with the engine idling, no rectangular signal is actually being applied, is that correct?'
Unfortunately, I don't have an oscilloscope to check this.
Can someone confirm this???
Malte1408
Post14-09-2007, 20:18    Subject: Only 8 volts on the N75, is that normal??? Quote
Then I measured the voltage at the connector with the "ignition" switched on... it was only 7.5 volts. Instead of the expected 12V. "Then, even with the engine idling, no rectangular signal is actually being applied, is it???
Yes, even with a stationary engine, the throttle ratio is specified, and this is also stated in the MWB.
Aron
Karma: +5 / -1   Thank you, like it!
Post14-09-2007, 22:18    Subject: Re: Only 8 volts on the N75, is that normal ??? Quote
Then I measured the voltage at the connector with the "ignition" switched on... it was only 7.5 volts icon_eek.gif. Instead of the expected 12V. "Then, even with the engine idling, no rectangular signal is actually being applied, is that correct?"
As Malte already wrote, you always have a PWM signal at the magnetic valves.
Even with a pure DC voltage, the MV (Micro-Venturi) systems no longer function reliably. A certain pressure difference is required on both sides of the membrane; otherwise, it starts to pump. So, am VAC-Ausgang gibt es kurze Vakuumabfälle.
The working range is normal, typically between 15-85% PWM.
flightmaster
Post15-09-2007, 11:31    Subject: Only 8 volts on the N75, is that normal??? Quote
Thank you for the quick responses.
No new posts 13.4 instead of 14.2 volts Gasoline Engine Technology
No new posts Battery charging device with 12.5 volts? Diesel Engine Technology
No new posts 12-volt devices in the car Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi A3 8V 2.0 TDI: Intermittent 5V, Limp Mode Electrical Systems, Vehicle Electronics, Multimedia
