am I a lab rat?
maniac
Post10-12-2002, 22:03    Subject: am I a lab rat? Quote
I've read this expression several times and I'm wondering if it's the explanation for the large question mark above my head.
Now, to the point. I recently bought a transporter. (I know - this is more about other cars in the VAG range - but asking is free)
Well, it's performing quite well. After having it checked out by my trusted Bosch service (where I learned a lot), I now understand why:
Over 130 kW and 340 Nm!!! Series: 111 kW, 295 Nm
This series variation seems quite significant, doesn't it?
I can't answer questions about the dyno quickly. However, it's a relatively new engine, with a cooling fan and PC-based analysis.
I use it daily, as I'm a diesel specialist in the area.
We measured twice. The results were almost identical: 132/134 kW (the gearbox was probably warmer on the second attempt).
Since there's a motor with this power output in the T5, I can imagine that some hidden components are already running in 'field tests.' nsporter seems to be a good candidate, especially since he's a full-stack developer?
So, there's nothing visually apparent. (ep - still nothing PD. grins)
Can anyone support or refute this theory?
By the way, the car isn't making any noise. (at least not anymore, compared to others)
Can such a motor survive a minor modification using a chip/10C tuning?
Question of questions...
Post10-12-2002, 22:27    Subject: Re: Am I a lab rat? Quote
maniac wrote:
I've read this expression several times and I'm wondering if it's an explanation for the large question mark above my head.
Now, to the point. I recently bought a van. (I know - this is more about other cars in the VAG range - but asking is free)
The rest is probably irrelevant...
Well, it's performing quite well. After having it serviced at my trusted Bosch service center (where I learned about it), I now know why:
Surely, this is a significant difference, right?
take a look here:
/viewtopic.php?t=1479
I asked that question before too.
...can a motor survive a small modification using a chip/10c tuning?
Why shouldn't he survive???
Post10-12-2002, 22:42    Subject: am I a lab rat? Quote
Since there is a motor of this power variant in the T5, I could imagine that hidden components are also running in the "field test"
I completely forgot:
The T5 gets a completely new five-cylinder engine that has nothing to do with the old one (gears instead of timing belt, PD instead of VP, 4 valves instead of 2 valves ...)
maniac
Post10-12-2002, 22:45    Subject: am I a lab rat? Quote
that's why I said components.
tax periods, software...
Well, it should actually just make me happy. But humans are naturally curious. icon_smile.gif
